Stankyz
PANIC: VFS: Unable to mount root fs on unknown-block(179,2)
Sat Jun 23, 2012 2:22 pm
After ~5 boots my Raspberry Pi:
Entering kdb (current=oxc7848c80, pid 1) due to Keyboard Entry
kdb >
It's not the first time, i already use 3 SD card with the latest kernel.
Install apache, reboot, install PHP, reboot, install MySQL, reboot, install no-ip, reboot. And *tadam* PANIC: VFS: Unable to mount root fs on unknown-block(179,2) !
- No keyboard
- No mouse
- No hdmi
(Only use ssh)
With or without ethernet, doesn't make any change ...
.IMG = debian6-19-04-2012 from http://www.raspberrypi.org/downloads
SD:
- Emtec SDHC 4GB Class 4
- Dance-Elec 2GB Class 4
- Intenso SDHC 4GB Class 4
What should I do ? I can't format every 5 boots !
I guess it's a bug with the damn filesystem ext4 ? :D
Regards,
Stankyz
dom
Re: PANIC: VFS: Unable to mount root fs on unknown-block(179
Sat Jun 23, 2012 2:48 pm
what does
uname -a
report? How are you rebooting?
I'd recommend using the Wheezy image:
http://www.raspberrypi.org/archives/1435
Stankyz
Sat Jun 23, 2012 2:58 pm
what does
uname -a
Nothing ... Can't type in kdb >
In ssh I used sudo reboot ...
Gonna try ,thx ! :)
EtiGre
Fri Jun 29, 2012 2:02 pm
Hi Stankyz,
Just to let you know, I found out your post because I see the exact same problem on my Pi.
I'm using the Wheezy Debian on a Sony SD card and if I electrically reboot the Pi (not with a clean shutdown -r), I'm sure to get a SD card corruption with the same message!
My solution so far: create a backup of my filesystem and "dd" it back at each reboot...
Cheers,
Eti
RaTTuS
Contact: Twitter YouTube
Fri Jun 29, 2012 2:07 pm
I've seen this on my system where I have the rootfs mounted on a USB HD - powercycling the USB HD fixes it.
I think something is not being cleanly flushed on reboot.
check your power.
Covfefe
ndpmcintosh
Thu Jul 12, 2012 7:18 pm
So what is the "real" solution to this problem?
I used RasPiWrite to set up my SD card. Tried it with Debian Squeeze, tried to use Debian Wheezy (but I couldn't get RasPiWrite to install it properly), and I just tried Fedora (installed with RasPiWrite) but its the same result every time. It makes no difference if I have a keyboard hooked up or not. I'm dead in the water and the RsP will not boot.
Any suggestions?
ndpmcintosh
Fri Jul 13, 2012 2:19 pm
Well, I solved my kernel panic (179,2) problem by not using a cheap (probably counterfeit) SD card delivered by boat from Hong Kong. Lesson learned.
mattanl
Sat Sep 15, 2012 10:10 am
I've found your message after having the same issue.
I bought SanDisk SDHC 16GB class 4 (which is verified).
I could buy the class 10 but I understood that these cards have problems with the raspi.
Can you recommend which card to buy?
Thanks.
cashlee
Fri Mar 01, 2013 5:53 pm
Oh my god.It seems that not myself's problem.I installed many things tonight and I use ssh to reboot my Raspberry Pi.
After that I found that I can't ssh to login into my Raspberry Pi.So I connect Pi with my monitor.I saw the same things kdb> .... .And the system did't work again.
Finally I tried to clean up the SD card on my Mac.But Macbook gave me many errors.
I think that I should go to buy a new SD card for Raspberry Pi.SAD. :cry:
leeiio
Sat Mar 02, 2013 1:18 am
I've also seen this on my Pi when I have the rootfs mounted on a USB HD, sometimes not very often.You can try to remove your USB HD and check whether the problem is not see again.
I don't know whether is my SD card's problem. My SD card is SanDisk 8GB Class10 UHS1.
Now everything is ok :mrgreen:
sidebarr
Sun Apr 07, 2013 4:20 pm
I had this same problem. As near as I am able to figure, it occurred because I unplugged my pi too soon after shutting down. I reflashed the the SD Card (Kingston 8gb, class10) with raspbian wheezy. I now use sudo poweroff in the terminal and wait until my TV/monitor says "No Signal" before I unplug the pi. I haven't had a problem since. I hope this helps someone.
