For the last 9 months I'd been using a Pi B, and I simply popped the Newbs I'd been developed software on into a new B+. I have noticed differences in how the piTFT is behaving compared to the B. (I did not verify that DNS was working on the B+ when it was at work.)
My kernel was recently fully updated (1 month ago) before getting at this. I was working with the piTFT.
At this time I'm able to use tightVNC to talk to the PI. It seems fine, but occasionally seems to pause, then continue. (Like its struggling to resolve something. It never used to do that.)
This is what I get on the command line on the PI.
pi@raspberrypi ~ $ cat /etc/hostname
raspberrypi
pi@raspberrypi ~ $ ifconfig -a
eth0 Link encap:Ethernet HWaddr b8:27:eb:23:c8:74
inet addr:192.168.0.100 Bcast:192.168.0.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:1031 errors:0 dropped:0 overruns:0 frame:0
TX packets:1253 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:50274 (49.0 KiB) TX bytes:196304 (191.7 KiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
pi@raspberrypi ~ $ cat /etc/resolv.conf
nameserver 192.168.0.1
pi@raspberrypi ~ $ sudo cat /etc/network/interfaces
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet manual
wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
pi@raspberrypi ~ $ route -n
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
0.0.0.0 192.168.0.1 0.0.0.0 UG 0 0 0 eth0
192.168.0.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0Code: Select all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Monster
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Intel(R) 82579V Gigabit Network Connection
Physical Address. . . . . . . . . : 54-04-A6-48-BC-15
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::d01b:803b:f5cb:b31c%12(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.104(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Saturday, November 08, 2014 8:23:22 AM
Lease Expires . . . . . . . . . . : Tuesday, December 15, 2150 6:10:38 PM
Default Gateway . . . . . . . . . : 192.168.0.1
DHCP Server . . . . . . . . . . . : 192.168.0.1
DHCPv6 IAID . . . . . . . . . . . : 257164454
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-16-CC-A2-32-54-04-A6-48-BC-15
DNS Servers . . . . . . . . . . . : 192.168.0.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter isatap.{181251E0-4F9A-4F55-9A07-4F9543CD19CD}:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Local Area Connection* 9:
Description . . . . . . . . . . . : Microsoft Teredo Tunneling Adapter
IPv6 Address. . . . . . . . . . . : 2001:0:9d38:6ab8:3472:32f:5e47:1fc0(Preferred)
Link-local IPv6 Address . . . . . : fe80::3472:32f:5e47:1fc0%10(Preferred)
Default Gateway . . . . . . . . . : ::
NetBIOS over Tcpip. . . . . . . . : Disabled
