BOOM! HEADSHOT
startx fails
Sat Nov 08, 2014 12:43 pm
returns xauth: timeout in locking authority file /home/pi/.Xauthority ”
I think this happened because I shut down pulling out the cord :oops:
I know there are a lot of topics but can anyone explain this to me step for step, every single step because I'm a complete noob, please... :roll:
DirkS
Re: startx fails
Sat Nov 08, 2014 1:59 pm
IIRC you can delete /home/pi/.Xauthority and the problem should be solved...
So after you log use the command
rm .Xauthority
Gr.
Dirk.
BOOM! HEADSHOT
Re: startx fails
Sat Nov 08, 2014 4:07 pm
DirkS wrote:IIRC you can delete /home/pi/.Xauthority and the problem should be solved...
rm .Xauthority
Gr.
Dirk.
How do I use the command, is there a prefix?
DirkS
Re: startx fails
Sat Nov 08, 2014 4:40 pm
what do you mean by prefix?
Because you use 'startx' I assumed you logged in to a command line. This would (when using user pi) get you to directory '/home/pi'.
From there the command I give should be sufficient to get the auth file deleted, but you can always use the full path.
Gr.
Dirk.
