spamurai
Shutting Down/Turning Off
Fri Jun 22, 2012 3:40 pm
Ok so i'm a COMPLETE newbie, but i wanted to check something before i go ahead and do it incase i break it :lol:
I've just logged out of the graphical interface and shut it down. The terminal has now stopped and it reads "System halted"...
I'm assuming its ok to pull out the power cable now(in order to turn it off)?
Sorry again for, what is probably a silly question. 8-)
There are 10 types of people in the world. Those that understand binary and those that don't!
01101000 01100001 01101000 01100001
SN
Re: Shutting Down/Turning Off
Fri Jun 22, 2012 3:45 pm
yup - system halted is the right state for pulling the power with no after-effects
Steve N – binatone mk4->intellivision->zx81->spectrum->cbm64->cpc6128->520stfm->pc->raspi ?
spamurai
Fri Jun 22, 2012 3:46 pm
SN wrote:yup - system halted is the right state for pulling the power with no after-effects
Thank you sir :D
alexeames
Fri Jun 22, 2012 4:14 pm
Yes. The Pi doesn't power down by itself. Once it says halted you can pull the plug safely :D
Alex Eames RasPi.TV, RasP.iO
Rodney Wertz
Sat Jun 23, 2012 6:22 pm
If you are using the command line type:
sudo shutdown -h now
unplug after it says the system is halted.
-Rodney
spamurai
Sat Jun 23, 2012 6:48 pm
Rodney Wertz wrote:If you are using the command line type:
-Rodney
Oh cool, thats handy to know. Thanks (:
I'm still looking into a switch I can adapt/use to turn the power off without unplugging it everytime. Proving difficult.
alexeames
Sat Jun 23, 2012 7:07 pm
-Rodney
And if you just want to reboot, you can change the -h for an -r
Actually I wrote a short blog post on shutting down properly earlier today (in case you're interested).
pbezza
Tue Jun 26, 2012 9:41 am
I started mineu up to test it but dont have a usb keyboard to plug in. What happens if i disconnect the power now without shutting down?
RaTTuS
Tue Jun 26, 2012 9:45 am
pbezza wrote:I started mineu up to test it but dont have a usb keyboard to plug in. What happens if i disconnect the power now without shutting down?
probably not a lot ...
it depends
it should recover
Covfefe
spamurai
Thu Jun 28, 2012 11:45 pm
alexeames wrote: And if you just want to reboot, you can change the -h for an -r
Thats an interesting read. Thanks for posting the link :D
Babbage6913
Tue Jul 03, 2012 6:17 pm
Hi all,
If you add -P to your shutdown command, it powers off, so try:
sudo shutdown -h -P now
I'm using the composit out atm, and with this command tv goes to a blue no signal screen. Not sure what happens with hdmi, so can someone test it and let us know?
Pat
Nr90
Tue Jul 03, 2012 7:27 pm
Babbage6913 wrote:Hi all,
Pat
It stays on system halted, does not power down.
Don't think you can power down from software in this case, it might just stop sending the composite signal.
alexeames
Tue Jul 03, 2012 9:44 pm
Nr90 wrote:It stays on system halted, does not power down.
Correct. In fact the current draw increases slightly on shutdown. :D
Once halted you have to pull the plug to power down (or switch if you have one set up).
dom
Tue Jul 03, 2012 10:19 pm
alexeames wrote: Correct. In fact the current draw increases slightly on shutdown. :D
Actually I pushed an improvement at the weekend where "sudo poweroff" now will try to reduce power.
You should see the Network LEDs go off, 10 flashes on OK LED and a low power state.
I'd be interested. If someone can measure current on 5V line now.
alexeames
Tue Jul 03, 2012 10:37 pm
Is that for both Squeeze and Wheezy?
Would a sudo apt-get update pull that one in in wheezy or does it need an rpi-update?
Once I get that sorted I can do a measurement :D
dom
Tue Jul 03, 2012 10:42 pm
alexeames wrote: Is that for both Squeeze and Wheezy?
You need an rpi-update. I don't believe Wheezy firmware package has been updated.
D.E.L.B.
Wed Jul 04, 2012 6:00 pm
Raspberry Pi does not shut down like the Windows OS does, you have to bear in mind that the Pi runs on a type of Linux OS depending on which one you use (Debian Squeeze, Arch Linux, QtonPi). Windows halts and powers down the physical computer at the same time.
The Pi does not, it needs to be halted AND then shut down by just pulling the power out of the mains of the Pi.
All you have to do is type sudo su while logged into the Pi account or one you have created, and type: halt.
It's as easy as that.
Mortimer
Wed Jul 04, 2012 6:14 pm
It's much easier to describe than that isn't it?
A PC or a Mac has a software controlled power switch, so the machine can turn itself off.
The Raspberry Pi does NOT have a software controlled switch, so you have to remove the power yourself.
The purpose of a little toe is to ensure you keep your furniture in the right place.
Nr90
Wed Jul 04, 2012 6:50 pm
Mortimer wrote:It's much easier to describe than that isn't it?
Indeed, Linux on x86 will also power down.
alexeames
Wed Jul 04, 2012 6:58 pm
OK Dom it goes from 5.00V 0.42A at cli idle
sudo halt
screen goes blank after "will now halt". LEDs go off apart from power
5.00-5.02V 0.12A
So that's a big power saving now from 0.42A to 0.12A - nice one. :D
About 2 watts at idle down to about half a watt.
ashbash
Thu Jul 12, 2012 11:55 am
Has anyone actually designed and created a shutdown switch yet? :o
I see a lot of talk on the forums about it but no action. I am planning to put one into the GPIO and poll for the state then initiate a shutdown after neatly closing any running software etc.
Any thoughts/comments.
Ash
See the switch portion of the circuit designed here - http://www.raspberrypi.org/archives/1417
