StoopKid
Easiest way to communicate with arduino through PHP
Sun Nov 02, 2014 2:06 am
I would like to be able to communicate with an Arduino with a website I am hosting on my Raspi.I have had trouble in the past trying to do GPIO stuff with php, I would end up having to edit a file then have a c++ program read the file to know what to do. And that c++ program wouldn't run as root automatically so I would have to run it in a tmux window so that wiringPi would work. I tried a bunch of tutorials to make wiringPi not require sudo but nothing worked. It was a real mess....
So what is the easiest way to do this? I just want to send a tiny amount of info to an arduino(an atmega328p, to be more particular, I'd like to avoid having to use the entire arduino) from a php script.
riklaunim
Re: Easiest way to communicate with arduino through PHP
Sun Nov 02, 2014 2:30 am
Serial connection maybe?
StoopKid
Sun Nov 02, 2014 4:14 am
That's what I was thinking but I was hoping someone had some experience with it so I don't jump into another thing that just gives me headaches.
StoopKid
Sun Nov 02, 2014 8:18 am
So yeah, trying to do serial with php and c++ are both giving me tons of problems. While I work on it, are there any suggestions for efficient alternatives?
B.Goode
Sun Nov 02, 2014 8:37 am
I haven't tried it, so I don't know if it is either possible or efficient, but how about a framework like firmata? There is a standard firmata sketch supplied with the arduino ide. There are php implementations/interfaces for firmata.
https://github.com/ThomasWeinert/carica-firmata
https://github.com/oasynnoum/phpmake_firmata
asandford
Sun Nov 02, 2014 12:20 pm
You can use MQTT (to publish messages) from php without requiring root.
A subscribing program can run as root and control GPIO.
Google MQTT Mosquitto
mahjongg
Sun Nov 02, 2014 1:06 pm
dont forgot to add level converters to the serial connection, to account for the fact that the PI uses 3V3 levels, while an arduino normally uses 5V.
Sun Nov 02, 2014 1:49 pm
asandford wrote:You can use MQTT (to publish messages) from php without requiring root.
With an ethernet shield on my Arduino and Nick O'Leary's MQTT library I can run MQTT on the Arduino.
http://knolleary.net/arduino-client-for-mqtt/
I've not yet tried running that with my SPI enc28j60 ethernet connected to my Arduino. That's an experiment for another day.
