I have tried to follow all the advice, hints, and tips I have been able to find without any success.
I have installed the latest official build of raspbian from Sept. 9'th downloaded from here. I have also tried to replace the bootcode.bin and start*.elf files without any success.
uname -a
Linux raspberrypi 3.12.28+ #709 PREEMPT Mon Sep 8 15:28:00 BST 2014 armv6l GNU/LinuxCode: Select all
lsusb -v
Couldn't open device, some information will be missing
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0 Unused
bDeviceProtocol 1 Single TT
bMaxPacketSize0 64
idVendor 0x1d6b Linux Foundation
idProduct 0x0002 2.0 root hub
bcdDevice 3.12
iManufacturer 3
iProduct 2
iSerial 1
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 25
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9 Hub
bInterfaceSubClass 0 Unused
bInterfaceProtocol 0 Full speed (or root) hub
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0004 1x 4 bytes
bInterval 12Code: Select all
dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.12.28+ (dc4@dc4-XPS13-9333) (gcc version 4.8.3 20140303 (prerelease) (crosstool-NG linaro-1.13.1+bzr2650 - Linaro GCC 2014.03) ) #709 PREEMPT Mon Sep 8 15:28:00 BST 2014
[ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] Machine: BCM2708
[ 0.000000] cma: CMA: reserved 8 MiB at 1b800000
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] On node 0 totalpages: 114688
[ 0.000000] free_area_init_node: node 0, pgdat c061dd90, node_mem_map c06cf000
[ 0.000000] Normal zone: 896 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 114688 pages, LIFO batch:31
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 113792
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=640 bcm2708_fb.fbheight=480 bcm2708.boardrev=0xf bcm2708.serial=0x2365cbd7 smsc95xx.macaddr=B8:27:EB:65:CB:D7 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 439532K/458752K available (4498K kernel code, 242K rwdata, 1344K rodata, 143K init, 701K bss, 19220K reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xdc800000 - 0xff000000 ( 552 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xdc000000 ( 448 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .text : 0xc0008000 - 0xc05bca24 (5843 kB)
[ 0.000000] .init : 0xc05bd000 - 0xc05e0eac ( 144 kB)
[ 0.000000] .data : 0xc05e2000 - 0xc061e8a0 ( 243 kB)
[ 0.000000] .bss : 0xc061e8ac - 0xc06ce080 ( 702 kB)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:394
[ 0.000000] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms
[ 0.000000] Switching to timer-based delay loop
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty1] enabled
[ 0.001169] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=10000)
[ 0.001229] pid_max: default: 32768 minimum: 301
[ 0.001749] Mount-cache hash table entries: 512
[ 0.002574] Initializing cgroup subsys memory
[ 0.002685] Initializing cgroup subsys devices
[ 0.002723] Initializing cgroup subsys freezer
[ 0.002755] Initializing cgroup subsys blkio
[ 0.002904] CPU: Testing write buffer coherency: ok
[ 0.003369] Setting up static identity map for 0xc04487f8 - 0xc0448854
[ 0.005307] devtmpfs: initialized
[ 0.021253] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 0.022838] NET: Registered protocol family 16
[ 0.028171] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.028865] cpuidle: using governor ladder
[ 0.028913] cpuidle: using governor menu
[ 0.029315] bcm2708.uart_clock = 0
[ 0.031400] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.031463] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.031498] mailbox: Broadcom VideoCore Mailbox driver
[ 0.031597] bcm2708_vcio: mailbox at f200b880
[ 0.031699] bcm_power: Broadcom power driver
[ 0.031736] bcm_power_open() -> 0
[ 0.031759] bcm_power_request(0, 8)
[ 0.532478] bcm_mailbox_read -> 00000080, 0
[ 0.532518] bcm_power_request -> 0
[ 0.532775] Serial: AMBA PL011 UART driver
[ 0.532948] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83, base_baud = 0) is a PL011 rev3
[ 0.891415] console [ttyAMA0] enabled
[ 0.918560] bio: create slab <bio-0> at 0
[ 0.924100] SCSI subsystem initialized
[ 0.928100] usbcore: registered new interface driver usbfs
[ 0.933803] usbcore: registered new interface driver hub
[ 0.939363] usbcore: registered new device driver usb
[ 0.945932] Switched to clocksource stc
[ 0.950203] FS-Cache: Loaded
[ 0.953374] CacheFiles: Loaded
[ 0.969264] NET: Registered protocol family 2
[ 0.975069] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.982485] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.989072] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.995518] TCP: reno registered
[ 0.998814] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 1.004687] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 1.011466] NET: Registered protocol family 1
[ 1.016453] RPC: Registered named UNIX socket transport module.
[ 1.022411] RPC: Registered udp transport module.
[ 1.027217] RPC: Registered tcp transport module.
[ 1.031939] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.039273] bcm2708_dma: DMA manager at f2007000
[ 1.044016] bcm2708_gpio: bcm2708_gpio_probe c05efef0
[ 1.049587] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[ 1.059172] audit: initializing netlink socket (disabled)
[ 1.064681] type=2000 audit(0.910:1): initialized
[ 1.235002] VFS: Disk quotas dquot_6.5.2
[ 1.239364] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.248338] FS-Cache: Netfs 'nfs' registered for caching
[ 1.255251] NFS: Registering the id_resolver key type
[ 1.260537] Key type id_resolver registered
[ 1.264745] Key type id_legacy registered
[ 1.269556] msgmni has been set to 874
[ 1.275286] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 1.283151] io scheduler noop registered
[ 1.287230] io scheduler deadline registered (default)
[ 1.292711] io scheduler cfq registered
[ 1.297922] BCM2708FB: allocated DMA memory 5bc00000
[ 1.302969] BCM2708FB: allocated DMA channel 0 @ f2007000
[ 1.310819] bcm2708_fb_pan_display(0,0) returns=0
[ 1.313384] Console: switching to colour frame buffer device 80x30
[ 1.313935] bcm2708_fb_pan_display(0,0) returns=0
[ 1.337631] bcm2708-dmaengine bcm2708-dmaengine: Load BCM2835 DMA engine driver
[ 1.348520] uart-pl011 dev:f1: no DMA platform data
[ 1.355733] vc-cma: Videocore CMA driver
[ 1.361368] vc-cma: vc_cma_base = 0x00000000
[ 1.367723] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.374641] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.391125] brd: module loaded
[ 1.401104] loop: module loaded
[ 1.406163] vchiq: vchiq_init_state: slot_zero = 0xdb800000, is_master = 0
[ 1.415626] Loading iSCSI transport class v2.0-870.
[ 1.423342] usbcore: registered new interface driver smsc95xx
[ 1.431154] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.638706] Core Release: 2.80a
[ 1.643420] Setting default values for core params
[ 1.649805] Finished setting default values for core params
[ 1.856960] Using Buffer DMA mode
[ 1.861771] Periodic Transfer Interrupt Enhancement - disabled
[ 1.869136] Multiprocessor Interrupt Enhancement - disabled
[ 1.876264] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.882130] Dedicated Tx FIFOs mode
[ 1.887493] WARN::dwc_otg_hcd_init:1042: FIQ DMA bounce buffers: virt = 0xdbc14000 dma = 0x5bc14000 len=9024
[ 1.900515] FIQ FSM acceleration enabled for :
[ 1.900515] Non-periodic Split Transactions
[ 1.900515] Periodic Split Transactions
[ 1.900515] High-Speed Isochronous Endpoints
[ 1.923207] dwc_otg: Microframe scheduler enabled
[ 1.923303] WARN::hcd_init:473: FIQ at 0xc0321550
[ 1.929540] WARN::hcd_init:474: FIQ ASM at 0xc0321800 length 36
[ 1.936987] WARN::hcd_init:500: MPHI regs_base at 0xdc806000
[ 1.944151] dwc_otg bcm2708_usb: DWC OTG Controller
[ 1.950630] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 1.961000] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 1.968145] Init: Port Power? op_state=1
[ 1.973613] Init: Power Port (0)
[ 1.978705] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.987137] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.997418] usb usb1: Product: DWC OTG Controller
[ 2.003681] usb usb1: Manufacturer: Linux 3.12.28+ dwc_otg_hcd
[ 2.011102] usb usb1: SerialNumber: bcm2708_usb
[ 2.018056] hub 1-0:1.0: USB hub found
[ 2.023474] hub 1-0:1.0: 1 port detected
[ 2.029453] dwc_otg: FIQ enabled
[ 2.029473] dwc_otg: NAK holdoff enabled
[ 2.029483] dwc_otg: FIQ split-transaction FSM enabled
[ 2.029503] Module dwc_common_port init
[ 2.029953] usbcore: registered new interface driver usb-storage
[ 2.038037] mousedev: PS/2 mouse device common for all mice
[ 2.045810] bcm2835-cpufreq: min=700000 max=700000 cur=700000
[ 2.053298] bcm2835-cpufreq: switching to governor powersave
[ 2.060544] bcm2835-cpufreq: switching to governor powersave
[ 2.067811] sdhci: Secure Digital Host Controller Interface driver
[ 2.075484] sdhci: Copyright(c) Pierre Ossman
[ 2.081429] sdhci: Enable low-latency mode
[ 2.126124] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
[ 2.137236] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
[ 2.144845] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.152323] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.162199] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.176821] usbcore: registered new interface driver usbhid
[ 2.184086] usbhid: USB HID core driver
[ 2.194221] TCP: cubic registered
[ 2.201252] Initializing XFRM netlink socket
[ 2.209256] NET: Registered protocol family 17
[ 2.215469] Key type dns_resolver registered
[ 2.228922] registered taskstats version 1
[ 2.235918] Waiting for root device /dev/mmcblk0p2...
[ 2.266803] mmc0: new high speed SDHC card at address 59b4
[ 2.274482] mmcblk0: mmc0:59b4 00000 7.35 GiB
[ 2.282072] mmcblk0: p1 p2
[ 2.382606] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.393998] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 2.403526] devtmpfs: mounted
[ 2.408716] Freeing unused kernel memory: 140K (c05bd000 - c05e0000)
[ 3.776114] udevd[156]: starting version 175
[ 5.713002] bcm2708-i2s bcm2708-i2s.0: Failed to create debugfs directory
[ 8.911313] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 9.382822] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 26.297637] Adding 102396k swap on /var/swap. Priority:-1 extents:1 across:102396k SSFSCode: Select all
ls /boot -al
total 9868
drwxr-xr-x 2 root root 16384 Jan 1 1970 .
drwxr-xr-x 22 root root 4096 Sep 8 20:03 ..
-rwxr-xr-x 1 root root 17840 Sep 8 20:24 bootcode.bin
-rwxr-xr-x 1 root root 120 Sep 8 21:26 cmdline.txt
-rwxr-xr-x 1 root root 1312 Sep 8 21:26 config.txt
-rwxr-xr-x 1 root root 2324 Sep 8 20:24 fixup_cd.dat
-rwxr-xr-x 1 root root 6115 Sep 8 20:24 fixup.dat
-rwxr-xr-x 1 root root 9166 Sep 8 20:24 fixup_x.dat
-rwxr-xr-x 1 root root 137 Sep 9 2014 issue.txt
-rwxr-xr-x 1 root root 3232856 Sep 8 20:24 kernel.img
-rwxr-xr-x 1 root root 18974 Sep 25 2013 LICENSE.oracle
-rwxr-xr-x 1 root root 533080 Sep 8 20:24 start_cd.elf
-rwxr-xr-x 1 root root 2615064 Sep 8 20:24 start.elf
-rwxr-xr-x 1 root root 3572200 Sep 8 20:24 start_x.elfThanks in advance.
