lilzz wrote:I have Pi unit running remotely by SSH into it. I do not need GPU therefore I like Pi to disable to converse power.
I have a custom voltage generator generates 5V to supply the Pi but voltage regulator is awfully hot as now.
I like to disable GPU and hopefully regulator gets less hot.
As Dougie said, you can't disable the GPU.
The GPU runs the Pi hardware (not just the graphics). The ARM CPU only runs the OS.
If your voltage regulator is getting hot then it is not a very good voltage regulator. It is probably something like a 7805 linear voltage regulator which gets rid of the extra voltage as heat which is very wasteful. It would be better to get a cheap switching voltage regulator (or UBEC circuit) which wastes very little power as heat.
