ygramoel
RT5370 Wireless Adapter not working on Darkbasic
Sat Oct 25, 2014 9:07 pm
I just plugged in a RT5370 Wireless Adapter ( Ralink Technology) into a USB port of my RPi B+ running a DarkBasic image.
It is recognized as a USB device but the driver is not able to create a network interface.
Below is the output of lsconfig, lsusb and (part of) dmesg. The part that worries me most is the line
pcm512x 1-004d: Failed to reset device: -5
in the output of dmesg.
What could be wrong/missing here?
root@cairon:~# ifconfig
eth0      Link encap:Ethernet  HWaddr b8:27:eb:42:ec:34
          inet addr:192.168.0.185  Bcast:192.168.0.255  Mask:255.255.255.0
          inet6 addr: fe80::ba27:ebff:fe42:ec34/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:9486 errors:0 dropped:0 overruns:0 frame:0
          TX packets:8255 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:1074863 (1.0 MiB)  TX bytes:3087412 (2.9 MiB)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:14748 errors:0 dropped:0 overruns:0 frame:0
          TX packets:14748 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:3489452 (3.3 MiB)  TX bytes:3489452 (3.3 MiB)
root@cairon:~# lsusb
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
Bus 001 Device 004: ID 148f:5370 Ralink Technology, Corp. RT5370 Wireless Adapter
root@cairon:~# dmesg | tail -20
[    4.959819] bcm2708_i2c_init_pinmode(1,3)
[    5.043303] cfg80211: Calling CRDA to update world regulatory domain
[    5.088029] bcm2708_i2c bcm2708_i2c.1: BSC1 Controller at 0x20804000 (irq 79) (baudrate 100000)
[    5.473106] usb 1-1.2: reset high-speed USB device number 4 using dwc_otg
[    5.744081] ieee80211 phy0: rt2x00_set_rt: Info - RT chipset 5390, rev 0502 detected
[    6.035971] ieee80211 phy0: rt2x00_set_rf: Info - RF chipset 5370 detected
[    6.141656] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[    6.143445] usbcore: registered new interface driver rt2800usb
[    6.526544] pcm512x 1-004d: Failed to reset device: -5
[    6.558540] pcm512x: probe of 1-004d failed with error -5
[    6.581122] pcm512x 1-004c: Failed to reset device: -5
[    6.593029] pcm512x: probe of 1-004c failed with error -5
[    7.846173] Adding 102396k swap on /dev/mmcblk0p3.  Priority:-1 extents:1 across:102396k SSFS
[    8.019678] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[   13.121594] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[   15.673930] NET: Registered protocol family 10
[   16.025907] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[   16.037073] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   17.558664] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
[   17.585792] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
pluggy
Re: RT5370 Wireless Adapter not working on Darkbasic
Sun Oct 26, 2014 3:46 pm
The obvious question has to be, what happens if you use a new download of Raspbian instead ? That way we know if its hardware or software we should be chasing.
I must not tread on too many sacred cows......
ygramoel
Sat Nov 01, 2014 5:24 pm
OK the wireless adapter works with full raspbian; the hardware is OK :-) . Something must be missing in darkbasic edition ...
Sat Nov 01, 2014 5:57 pm
ygramoel wrote:OK the wireless adapter works with full raspbian; the hardware is OK :-) . Something must be missing in darkbasic edition ...
Can you copy the /boot/* stuff (kernel and firmware stuff) and /lib/modules/`uname -r`/* kernel modules from Raspbian to your Darkbasic system so that you get a working version of the RT5730 driver?
Or look at getting a newer version from the Darkbasic owners.
Or wire your RPi to the network and use rpi-update to do that stuff automagically.
