i have big problem with my Raspberry. I tried search on forum, i tried google, but i don't find solution (maybe don't exist) :/
When i plug power to my Raspi, few seconds i see "boot informations", but after maybe 6-7 seconds is monitor turned off and this is end of any actions (monitor don't have a signal and his try swich between HDMI and Analog input).
I tried boot with "NOOBS loader": After plug in power i see interface with selection actions (install Raspbian, ...), but maybe after 5-6 second, is monitor turned off and i see same scenario like a first case :/
Video: https://www.dropbox.com/s/yczs69ox57iq2 ... 5.mp4?dl=0
I tried edit config.txt and currently is:
# For more options and information see
# http://www.raspberrypi.org/documentation/configuration/config-txt.md
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
hdmi_safe=1
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
(Raspberry Pi model B; Power 5V / 1A)
Any ideas? Or is my Raspi half dead?
Really thanks for any answers.
