correiaf wrote:After 4 hours of downloading and installing bits and bobs of the same code over and over again the piglow and respective Py are soon to make an early exit off the shelf and on towards the bin.
I have followed everything blocked and unblocked 2708 parts and all that and not once does it work. all I constantly get is ImportError: no module named Pyglow even if the code is in the same folder and I ran PyGlow first. Sadly no look on Google helps me find a solution.
Fun times while they lasted...
try changing the reference to PyGlow instead of Pyglow. Case is very sensitive and won't play if it's feelings are hurt.
Is this the line where you have a problem?
check the spelling of the pyglow.py program and ensure that it matches the first reference.
open pyglow.py
and check that the PyGlow module is spelt in the same fashion.
Doug.
