Hey guys,
I wanted to update and optimize my nginx server today. After the apt-get update,upgrade and even dist-upgrade, I went on to building the Pagespeed module for nginx from Google:
https://developers.google.com/speed/pag ... rom_source
(Everything is done as su)
But in the end I got this error:
configuring additional modules
adding module in /var/www/ngx_pagespeed-release-1.9.32.1-beta //yes I stored it in my www folder, just temporary.
Architecture not supported: armv6l
something@something:~/nginx-1.7.6# sudo make
make: *** No rule to make target 'build', needed by 'default'. Stop.
Too bad for ARM users, but according to:
https://github.com/pagespeed/ngx_pagespeed/issues/398
It seems I have to follow these steps:
https://github.com/pagespeed/ngx_pagesp ... rom-Source
And that should do it.
But running the first bash for building results in this:
something@something:~/mod_pagespeed# sudo client config http://modpagespeed.googlecode.com/svn/ ... .32.1/src/
sudo: client: command not found
I cannot find a solution for it, but in my google search I found that it might have something to do with my PATH variable, somehow?
Not that it should make any diffrence but, I am running raspbian with jessie instead of wheezy.
Thanks in advance,
Arndroid
