Christian123
Display, how to start GUI?
Tue Oct 21, 2014 7:58 am
I have bought a Adafruit PiTFT - 2.8" Touchscreen Display for Raspberry Pi. There’s a descripition for the installation of the touchscreen Display under https://learn.adafruit.com/adafruit-pit ... sy-install. I took the easy install possibility and it worked. That means I can use the Terminal and print Images on screen.
My problem is that I don’t know how to start the GUI/Desktop??
Thanks in advance.
B.Goode
Re: Display, how to start GUI?
Tue Oct 21, 2014 10:22 am
Do the instructions in the adafruit documentation not work?
https://learn.adafruit.com/adafruit-pit ... s-on-pitft
DirkS
Tue Oct 21, 2014 10:43 am
And if you want to start the GUI from the command line:
FRAMEBUFFER=/dev/fb1 startx
Or you can add a line to .profile (if the auto setup has not done that already) and just use startx.
From https://learn.adafruit.com/adafruit-pit ... stallation:
You can now try to run X again with
Type Control-C to quit X
If you don't ever want to have to type FRAMEBUFFER=/dev/fb1 before startx, you can make it a default state by editing your profile file: sudo nano ~/.profile and adding
export FRAMEBUFFER=/dev/fb1
near the top and saving the file. Then reboot to reload the profile file. It will now always assume you want to use /dev/fb1
Gr.
Dirk.
Tue Oct 21, 2014 11:20 am
Follow the instructions here: https://github.com/notro/fbtft/wiki/Framebuffer-use
You need to create an xorg.conf.d file to force X to use the FB1 device.
Christian123
Fri Oct 24, 2014 7:37 am
You are right. I forgot the "FRAMEBUFFER=/dev/fb1 startx" command. It's working now.
Thank you all very much.
