bbno3
No usb device works?
Mon Oct 20, 2014 6:27 pm
Hello all!
I am having trouble connecting my Pi to the internet, i have tried 2 different Wifi Dongles, an Edimax (which worked before) and the one it came with (which also worked before). Both of these work on Raspbian, however since i want to use Musicbox none of these devices work, in fact no USB device works on Musicbox, but does work on Raspibian.
Any ideas?
also i cannot connect it to ethernet since the place i am currently staying at doesn't allow that :(
pluggy
Re: No usb device works?
Mon Oct 20, 2014 6:56 pm
Is it a Pi B+ ?. USB needs modern "firmware" to work with a B+. Musicbox may not be late enough.
bbno3
Mon Oct 20, 2014 7:00 pm
Ah no, it's a normal Pi B. Sorry for missing out so much info, i don't know what to include considering i can only use the terminal if i put raspbian on it, none of the USB's appear to work in Musicbox, although it does see that i have a USB device plugged in (the wireless dongle). I've repeatedly checked to make sure that all wireless credentials are correct, and have even attempted to connect to a different network all together, but no luck! :cry:
Also Raspbian FULLY works with ALL of my wireless dongles!
Is there a way to get Mopidy on Raspbian? Since all i want is a spotify server :cry:
bbno3
Tue Oct 21, 2014 7:15 am
Bump
Tue Oct 21, 2014 7:27 am
bbno3 wrote:Ah no, it's a normal Pi B. Sorry for missing out so much info, i don't know what to include considering i can only use the terminal if i put raspbian on it, none of the USB's appear to work in Musicbox, although it does see that i have a USB device plugged in (the wireless dongle). I've repeatedly checked to make sure that all wireless credentials are correct, and have even attempted to connect to a different network all together, but no luck! :cry:
Did you net check out the Mopidy web site ? https://docs.mopidy.com/en/latest/installation
RPi 4B 4GB (SSD Boot)..
bbno3
Tue Oct 21, 2014 8:14 am
Now all USB ports aren't working, great.
RaTTuS
Contact: Twitter YouTube
Tue Oct 21, 2014 8:18 am
take a new SD card ,
flash the latest rasbian on it
what happens
also
see sig
Covfefe
bbno3
Tue Oct 21, 2014 4:00 pm
RaTTuS wrote:take a new SD card ,
what happens
also
see sig
It boots into Raspi Config, but i can't use the keyboard properly. the only button i can use is Enter. it's all plugged into a USB hub
RaTTuS
Tue Oct 21, 2014 4:17 pm
can you ssh into it and type
dmesg
what keyboard and hub [is it powered]
Covfefe
B.Goode
Tue Oct 21, 2014 4:39 pm
bbno3 wrote: It boots into Raspi Config, but i can't use the keyboard properly. the only button i can use is Enter. it's all plugged into a USB hub
That's odd, because you said last night
Like @RaTTuS I'd like to know is the USB hub independently powered, or are you sucking power out of the RPi to try to drive the usb devices? Maybe this is a power supply issue?
