leejohnson
raspbian and arch on pi
Mon Oct 20, 2014 9:56 am
hey guys,
when i bought the noobs sd card, it gave me the option to install i list of operating systems,
i installed rasprian and arch linux, after playing around i like raspbrian.
how do i unistall arch linux please.
i have user access and root access if that helps.
B.Goode
Re: raspbian and arch on pi
Mon Oct 20, 2014 12:01 pm
leejohnson wrote: how do i unistall arch linux please.
Short answer: you don't. NOOBS is a no-frills Installer - it doesn't have tools for UNinstalling.
Medium answer: the NOOBS recovery console allows you to select the OSes to install. So by going back to NOOBS by using Shift when prompted at boot-up you can choose to install ONLY Raspbian. But note that you will erase/overwrite your existing installation of Raspbian and any files/projects that you have worked on.
Long answer: if your concern is to reclaim SD card space, then it is theoretically possible to use a partition editor like gparted to reconfigure the partitions on the SD card. If you knew how to do that, I suspect you wouldn't have asked the question...
pluggy
Mon Oct 20, 2014 12:57 pm
If you've settled on Raspbian, I'd abandon NOOBS and just put Raspbian direct from the image.
leejohnson
Mon Oct 20, 2014 1:05 pm
thanks for the reply,
i really do need to keep the files saved on the sd card on there,
so how do i "abandon NOOBS and just put Raspbian direct from the image" ???
RaTTuS
Contact: Twitter YouTube
Mon Oct 20, 2014 1:17 pm
copy you changes elsewhere and reflash just using raspina image then copy tour files back
Covfefe
