http://www.cl.cam.ac.uk/projects/raspbe ... mperature/
I've bought everything and it is my first project and pi. I do have the B+, but I don't think it is an difference.
When I run this:
sudo modprobe w1-gpio
sudo modprobe w1-therm
cd /sys/bus/w1/devices/
ls
I don't get the results that are displayed. I have flipped the resistor about four times. I pulled out a volt meter (luck I had one) and I'm sending power from the board. I kept feeling it to see if it was getting warm. I researched the pins. However, being a novice, I tried all the connection combinations I could try. I'm thinking I possible blew the sensor. I did put the volt meter on the grnd and power and I can see that power is flowing. However, the first couple times I setup the device, my pi wouldn't startup. lol, I have no idea what I'm doing, but I'm trying. However, I could use some help if possible.
