Hey,
I have a problem when connecting PIR module as it seem always to by HIGH. I went throught the parent detector article and connect as per article but when i execute the pirtest.py in allways says the PIN is HIGH, when I manually remove the cable it goes to LOW state.
First I thought it is the PIR sensor, so I bought new one but the same result, so I bought new Raspberry Pi but I have the same result. I have changed the cables, but the result is the same. Can anyone think of a reason why that would be?
