Thoughts, comments and clarification of value of R1 in attached ckt. diagram for use with Pi GPIO output as a level shifter.
The way I read the diagram R1 varies between 4k and 7k as the voltage applied is varied between 5V and 30V. Is that correct?
I am making plans to build a GPIO breakout board for the Pi B+ and intend to use two (2) SN7407 ICs to make available 12 buffer circuits (3.3V to 5V level shifter) for connection with motor controllers, servo controllers, sensors, and other bells / whistles I will be cobbling in the future as the Pi bot gets built-out over time.
In addition to the level shifter for GPIO outputs, I intend to include a number of voltage dividers on the breakout board to protect the Pi GPIO inputs.
The above circuits, along with other Pi GPIO protection circuits, can be found at:
< http://elinux.org/RPi_GPIO_Interface_Circuits >
Thank you for any thoughts and comments you may share.
P.S. I cannot seem to attach the file of the circuit diagram referenced above -- it can be found at the elinux webpage sighted above. My apologies, it appears that this forum does not accept Open Office files - so it goes - cheers
