Hi all,
I have searched online quite a bit but not really found an answer that has proved sufficient.
So I bought a Raspberry pi B+, with plans to add an 3.5" Western Digital Red (as a backup solution).
I have read that one should by the model B+ so one can unlock the extra power needed for external hard drives.
However isn't this only if the HDD is a 2.5" (since they usually only require 500 mA to run)? and therefore one would have a setup as follows:
Power adapter 2.0A 5V ----> Raspberry Pi B+ ------> USB to SATA cable ----> 2.5" HDD
But since I have a 3.5" 500 mA (USB 2.0 max power output) will not be sufficient ergo a setup like this is needed:
Power adapter 1A 5V ----> RaspBeryy Pi (standard model) ----> USB to SATA cable ----> 3.5" HDD <------ new Power adapter 1.2-ishA with 5V
Since the Pi no longer can run the HDD a dedicated power source and a regular PI might be enough?
Or am I wrong? Are there better solutions for my use of 3.5" HDD?
