Is it possible to use two Pi as some kind of relay between networks?
Say I have an Internet connection to one building on the property and there is another about 100 m away that I also want to be connected but I don't want to pull a network cable across.
Could I use two Pi units as some kind of bridge between the two using a WiFi link?
For example if I use a cantenna in each end and have the Pi WiFi adapter located in each cantenna to talk to the other end, would this be a way to connect the two buildings as a network?
I guess it would be doable, but how can I do it with a couple of Pi units to route the traffic from the remote building through to the Internet?
I really need to get to grips with the configuration on each of the two Pi units....
Ideally the remote building would have its own WiFi router that is fed by the link to the first building as its Internet connection. So all devices connected to the remote building WiFi would have an Internet connection via the network on the first building.
