makiss8
cant read sd
Mon Oct 13, 2014 5:00 am
hello to all, i am new here!
well, the first time i put the noobs edition on sd, i connected to raspberyy, i choose the recommened operation all good!
the next time i format again the sd, and i put again noobs edition, at the raspberry i can only choose raspbian nothing else!
*with image writer i wrote an image opele and the sd was empty no files after the image writer completed..
help!
thanks
Palmcrack
Re: cant read sd
Mon Oct 13, 2014 8:17 am
Dear friend.
After the first use of an SD card on it, you receive 1 FAT partition just 56Mb! Perhaps the problem is that you need before formatting the card using Raragon Partition delete all partitions from the card SD, and then create a partition and format it in FAT
makiss8
Re: cant read sd
Mon Oct 13, 2014 8:28 am
thanks for your answer.
what are the programmes you are using for format and image write for the rapsb?
thanks again
Palmcrack
Re: cant read sd
Mon Oct 13, 2014 8:40 am
I use Paragon Partition Manager but can any other
makiss8
Re: cant read sd
Mon Oct 13, 2014 8:44 am
what about for images? how you burn the image ? like openelec ?
Palmcrack
Re: cant read sd
Mon Oct 13, 2014 8:52 am
I'm using raspbian. Stitch using win32diskimager, as many users
B.Goode
Re: cant read sd
Mon Oct 13, 2014 8:53 am
makiss8 wrote: the next time i format again the sd, and i put again noobs edition, at the raspberry i can only choose raspbian nothing else!
That is to be expected. From the announcement of the latest release of NOOBS on the Raspberry Pi Foundation Blog -
Finally, to free up SD card space, the offline NOOBS package now only contains the Raspbian archive. To install Arch, Pidora, OpenELEC, RaspBMC or RISC OS you will require a network connection.
Re: cant read sd
Mon Oct 13, 2014 8:54 am
makiss8 wrote:hello to all, i am new here!
help!
thanks
All the information is on the RPF Website http://www.raspberrypi.org/downloads ;)
Regards Noobs the latest version only includes Raspbian Wheezy.
RPi 4B 4GB (SSD Boot)..
makiss8
Re: cant read sd
Mon Oct 13, 2014 8:57 am
i dont understand this. i can only choose raspbian to install. how with the internet connection i will download the otelenec ?
thanks for your time
Re: cant read sd
Mon Oct 13, 2014 9:04 am
makiss8 wrote:i dont understand this. i can only choose raspbian to install. how with the internet connection i will download the otelenec ?
You need to be connected to the Internet and use the Other Operating System Option, unfortunately the instructions are still out of date and myself gave up with Noobs and install each OS on a seperate SD Card
B.Goode
Re: cant read sd
Mon Oct 13, 2014 9:06 am
OpenELEC?
Just read the documentation.
https://github.com/raspberrypi/noobs/bl ... stallation
In short - connect your RPi to the network, select OpenELEC from the NOOBS 'console', and click on Install.
makiss8
Re: cant read sd
Mon Oct 13, 2014 9:09 am
thats my problem.. there is nothing to select except the raspbian.
RaTTuS
Contact: Twitter YouTube
Re: cant read sd
Mon Oct 13, 2014 9:12 am
makiss8 wrote:thats my problem.. there is nothing to select except the raspbian.
http://www.raspberrypi.org/forums/viewt ... 25#p625875
Covfefe
makiss8
Re: cant read sd
Mon Oct 13, 2014 9:15 am
i see.. THANKS for you time mate!i will try it when i go back from work and i will post the results :)
makiss8
Re: cant read sd
Mon Oct 13, 2014 2:33 pm
guys... i tried everything.. nothing is working.. still i can choose only raspbian... :/
B.Goode
Re: cant read sd
Wed Oct 15, 2014 9:21 am
I think you have overlooked the first step. (Or you do not have a working internet connection for your RPi.)
If NOOBS does not have a working internet connection it will not offer you the opportunity to install additional Operating System over a network connection.
makiss8
Re: cant read sd
Wed Oct 15, 2014 11:57 am
thank you all, the problem was that the image raspbianxbmc for the forum wasnt working. from another site worked!
