Zergei72
Lightweight Audio / MIDI - HDR-Sequencer
Sun Oct 12, 2014 6:22 pm
okay ... ;
i'm planning to build a mobile DAW, with my Raspberry P Bi+ as its' core .
The Audio-Hardware would consist of a Zoom H4n-USB2-external sound-card and a Roland TMC-6 (6channel Trigger to MIDI-controller) .
My goal is to record 2 tracks of audio (the zoom is limited to 2channels when used as a USB-device) and 4 tracks of MIDI triggered and transmitted by the Roland .
I would like to know what would be the best software solution (DAW) to be used on my Pi B+ .
I only need to record 2tracks of audio and 4 of MIDI (so I guess I won't be needing anything cpu-huggy ?) .
on the other hand ...
If someone knows how to build Ardour 3 for Raspberry Pi I'd be glad to hear out as version 2 doesn't support MIDI-recording (as far as I know ...)
- zergei W -
r3d4
Re: Lightweight Audio / MIDI - HDR-Sequencer
Sun Oct 12, 2014 7:32 pm
RE:
Zergei72 wrote:If someone knows how to build Ardour 3 for Raspberry Pi I'd be glad to hear out as version 2 doesn't support MIDI-recording (as far as I know ...)
I have not tryed it but ...
AutoStatic wrote:Ardour simply isn't made for devices like the RPi. Maybe Qtractor or non-daw work better. Those DAWs should work after you've properly configured your RPi by following http://wiki.linuxaudio.org/wiki/raspberrypi
http://www.raspberrypi.org/forums/viewt ... 61#p328661
Real life is, to most, a long second-best, a perpetual compromise between the ideal and the possible.
Meanwhile, the sysadmin who accidentally nuked the data reckons "its best not run anything more with sudo today"
what about spike milligan?
