dhruvvyas90
Remote access using ISPs with NAT.
Wed Oct 08, 2014 6:34 am
I have deployed quite a few embedded products based on Raspberry pi and now to provide them support I would like to introduce remote access in my products. I have experimented with a few ISPs that provides static IPs and it works like a charm however, a few ISPs use NAT and don't provide static public ip directly to device but they use NAT based systems instead. I was wondering if there's a way to gain remote access in this situation.
Any help will be appreciated.
Thanks.
ghans
Re: Remote access using ISPs with NAT.
Wed Oct 08, 2014 6:45 am
1) Set up a VPN server on your premises and have the Pis connect to it.
2) Set up a SSH server on your premises (i.e. another Pi) and use reverse SSH tunneling
on the clients.
ghans
cpc464
Wed Oct 08, 2014 12:41 pm
Hi OP can you give more details - where the target Pis are (all in the same remote place, scattered), what sort of access you want (ssh/desktop) and where you are connecting from.
Unix engineer since 1989
dhruvvyas90
Sat Oct 11, 2014 8:07 am
cpc464 wrote:Hi OP can you give more details - where the target Pis are (all in the same remote place, scattered), what sort of access you want (ssh/desktop) and where you are connecting from.
Targeted Rpis are scattered, of course. Just SSH is fine, ie I don't need remote desktop currently. I will be connecting from different state / country. I just need an option to connect to Rpi on the ISPs those do not provide static IP. Solution provided by ghans should work but I am yet to test it.
dhruvvyas90
Sun Oct 12, 2014 10:39 am
I just tried the method mentioned by ghans. It works like a charm.
Also, there is a blog post that addresses the same question.
http://www.tunnelsup.com/raspberry-pi-p ... ssh-tunnel
Hope it helps for others who are trying to achieve the same.
Thanks again, ghans. :)
