I have a Raspberry Pi model B+, and I use it with RaspMBC to use it as a media centre. It worked flawless in the beginning (4 days ago), but lately it suffers from random reboots.
I've got 2 external Hard drives, hooked up to a hub, all three of those powered on their own. The USB from the hub is the only USB connected to the Raspi. I am then connected to my TV using HDMI, with CEC enabled. Lastly I have a standard patch cable connected for my network.
I've read in other posts it can be caused by either too low power input, but I've tried with different chargers, including a standard Samsung charger which delivers 2A at 5V. I have no access to a multimeter however, so I haven't been able to measure the voltage on the board itself. I do however, have it plugged in a power strip, along with lots of other things (about 10 things - a lot, I know).
Other posts inform me that overclocking could be the cause, but I am not doing this. At least, not to my knowledge.
I also read that it could be caused by low memory, but I have no idea how that could happen. I use it in a normal fashion, just to watch movies or series, and nothing more. When I enable debugging, I can see that there is no drastic lowering of my free memory or increase in CPU.
The reboots happen at random times, but I've noted some patterns. It only reboots when I'm watching a clip in 1080p. Smaller videos play without trouble.
I have tried to reinstall it, with success, but the reboots continue. For no reason at all, suddenly it just shuts down and starts up again. I've already enabled dirty rendering.
I can understand that I can be the umpteenth noob that asks this question, but any help you can give will be much appreciated.
EDIT: Posted the log files as well. I can find nothing of note in it.
