SnorriChinchilla
sh: can't access tty; job control turned off
Mon Oct 06, 2014 7:53 pm
Whenever I boot up my Raspberry pi I have started getting this error message after it flashes from the rainbow screen
I shorted the 7 and 8 pins once when this came up and it booted normally. But now I tried it again and it didn't work.
How can I boot up again?
BlackberryTart
Re: sh: can't access tty; job control turned off
Tue Oct 07, 2014 1:14 am
Did you try reinstalling the OS? That may help if there is a software problem/corrupted files.
I looked it up and the internet seems to agree to changing a config file.
Yes, it is usually safe to add avoid_safe_mode=1 to config.txt. An exception might be if you are overclocking but other than that, just go ahead and try. You can read more about it here
http://elinux.org/RPI_safe_mode
The config.txt file is in /boot
https://raspberrypi.stackexchange.com/q ... turned-off
I found the answer on Google, I recommend you look there first.
Blackberry tarts are sort of like raspberry pies, but they are more purple and sour.
BlackberryTart
Tue Oct 07, 2014 1:16 am
http://www.raspberrypi.org/forums/viewt ... 96&t=62106 looks like someone had asked the same question already.
Joy
Mon Jul 02, 2018 9:20 am
that thread is different than this
