aTao wrote:How accurate do you need?
Have you thought of painting (sticking a printed lable) onto the shaft (axle, not axe btw), then using opto sensors?
Is there something already attached to the axle that you can measure.
We really need much more info than you have given, a picture would be great.
Hi guys and thanks for your answer.
My goal is to use any sensor to determine the relative positions of the two axis of an astro telescope equatorial mount (this type :
http://www.pulsar-optical.co.uk/magnify/155.1.html).
Here is a picture I took :
http://www.webastro.net/upload/images/2 ... 192865.jpg
I think I need to have an accuracy of 1 degree only (when you point a presumed stellar object position with 1 degree accuracy, you should have it in the 25x finder).
As you can see in the picure, there are some graduations on the axe (there is another one in the other axe). In concrete terms I need to get this values (to calculate some others). Naturally there will be a calibration phase to get the "zero" value.
I thought about some kind of opto sensors but I did not found any to do it. Do you think about a specific sensor ?
I thought also to something like a potentiometer line (as mentioned in the second answer) but I wonder if it should be enough strong : the telescope on the mount can be turned on the two axe with fine motion commands, but by a free hand way too on the movments should a little fast and repetitive, no ? (and the monnt is used outdoor with potentially some humidity issues)
I hope this explanation should help you to have a better idea of what I try to do ...
Thanks again.
Regards
