tftdrd60
Can I configure user pi to have superuser rights?
Wed Oct 01, 2014 3:33 pm
I am getting some success with the Rpi and want to get my application to run automatically at startup.
I wonder if there is a way to permanently assign sudo rights to pi so the program works without me having to go into terminal?
It's this 'no access to /dev/mem' bit that's bugging me... I've got it to work using sudo python test2.py but surely there is a way to configure pi to have admin rights at start up.
Thank you
joan
Re: Can I configure user pi to have superuser rights?
Wed Oct 01, 2014 4:04 pm
sudo is normally configured by default to give the pi user superuser rights.
Why do you think you can't launch an application at start-up?
Wed Oct 01, 2014 4:07 pm
If you move the pi userid to UID(0) and GID(0) it becomes a root id.
Or assign a password to root with sudo passwd, lock or delete pi and just login as root every time.
raspfakehuman
Wed Oct 01, 2014 5:39 pm
Set suid on the program? If it is just for setup, do suid for setup only.
hippy
Wed Oct 01, 2014 9:56 pm
I'm having the same problem trying to run a python script when logged in as "pi". The program imports RPi.GPIO to access the GPIO pins. Run with sudo it works as expected but no joy in getting it to run using a simple ./blink.py
Tried every combination of chown and setting SUID but still no joy ...
pi@raspberrypi:~$ ls -l blink.py
-rwsr-sr-x 1 root root 312 Oct 1 21:32 blink.py
pi@raspberrypi:~$ ./blink.py
File "./blink.py", line 7, in <module>
GPIO.setup(pin,GPIO.OUT)
RuntimeError: No access to /dev/mem. Try running as root!
Is the problem that python itself doesn't have superuser execution rights ?
DirkS
Wed Oct 01, 2014 10:09 pm
Correct. You are actually not running the .py script, but the python program itself where the script is just an input file. So setting suid on the script has no effect at all.
Gr.
Dirk.
Wed Oct 01, 2014 10:13 pm
DirkS wrote:Correct. You are actually not running the .py script, but the python program itself where the script is just an input file. So setting suid on the script has no effect at all.
It's a horrible security exposure but you could make /usr/bin/python a suid program.
hippy
Wed Oct 01, 2014 11:20 pm
Thanks. In my case the desire was simply to save on typing so the easiest solution seems to be to create a ./blink.sh and run that. That can have sudo python blink.py in it which retains maximum security elsewhere and avoids having to uses chown/chmod.
Thu Oct 02, 2014 10:49 am
You could try changing the shbang line on your script to
#!/usr/bin/sudo /usr/bin/python
which should make it work without doing nasty things with permissions and suid bits.
hippy
Fri Oct 03, 2014 12:47 pm
rpdom wrote:You could try changing the shbang line on your script to
Excellent - that worked perfectly.
It seems that "#!/usr/bin/sudo python" is enough.
I had searched on Google for using sudo within shebang but did not find anything useful. Tried a few things but hadn't found the magic incantation.
