I'm new to the Pi and I'm still on the learning curve of learning python, Is it possible to send an image downloaded using.urlretrieve of Python and then send it to the printer to print it!
I've not tried this, but this is the approach I'd take:
1) Forget all about python to start with
2) Find out how to print from the command line (a quick google suggests installing cups and using the lpr command) and work out what command you need to run, including options to scale image etc.
3) Time for python...
4) Download file
5) Use subprocess module to call the "lpr" command (plenty of examples of using subprocess on this forum)
RPi Information Screen: plugin based system for displaying weather, travel information, football scores etc.
but I would like to ask if its feasible if for example the downloaded image will then be copied or be framed into a template , for example , be printed like a polaroid picture ?
