I am used to check the incoming voltage on the Pi to see if there is a problem with the supply.
On the Model B there were test points that could be used for this, but I cannot find any on my newly bought B+.
So how can you check what is actually delivered to the Pi after the supply drop because of load and the cable drop because of thin wires?
I would like to measure the voltage on the Pi board itself somehow.
