lilzz
CURL 's readback function
Fri Sep 26, 2014 4:06 am
        const char data[]="this is what we post to the silly web server";
        struct WriteThis {
          const char *readptr;
          long sizeleft;
        static size_t read_callback(void *ptr, size_t size, size_t nmemb, void *userp)
          struct WriteThis *pooh = (struct WriteThis *)userp;
          if(size*nmemb < 1)
            return 0;
          if(pooh->sizeleft) {
            *(char *)ptr = pooh->readptr[0]; /* copy one single byte */
            pooh->readptr++;                 /* advance pointer */
            pooh->sizeleft--;                /* less data left */
            return 1;                        /* we return 1 byte at a time! */
          return 0;                          /* no more data left to deliver */
     struct WriteThis pooh;
      pooh.readptr = data;
      pooh.sizeleft = (long)strlen(data);
         curl = curl_easy_init();
          if(curl) {
            /* First set the URL that is about to receive our POST. */
            curl_easy_setopt(curl, CURLOPT_URL, "http://example.com/index.cgi");
            /* Now specify we want to POST data */
            curl_easy_setopt(curl, CURLOPT_POST, 1L);
            /* we want to use our own read function */
            curl_easy_setopt(curl, CURLOPT_READFUNCTION, read_callback);
I do not see how the parameters of read_callback () got initialized. ptr, size and nmmemb and usurp.
Return to “C/C++”
