apples723
None wanting to use a relay switch
Tue Sep 23, 2014 4:12 am
How would I go about controlling this[img]
http://postimg.org/image/vmgq6ipv1/full/[/img] with a relay switch an raspberry pi via a browser.
I need a nube guide to relay switches and automation.
What do I need to buy as this a light switch and most guides I found online talk about ac outlets. I know basic python. And have been using Linux for a couple of years as well as html, but never could get node to work on my pi and I don't have vps hosting so my web host doesn't support node :( also id like to know if I can control my remote control outlets that have a basic on and off remotefrom the same relay switch. And could I fbuy something to power the pi using he light switch power because id like to actually put this in the wall next to the switch and obviously would use WiFi but it be difficult to run power to the pi in the wall.
johndough
Re: None wanting to use a relay switch
Tue Sep 23, 2014 10:09 am
Hiya
MAINS ELECTRICITY IS LETHAL.
Maybe something here that could help...
http://www.raspberrypi.org/forums/viewt ... 17#p544917
If in doubt please ask.
apples723
Tue Sep 23, 2014 6:50 pm
So ur saying a light switch has too much power?
toxibunny
Tue Sep 23, 2014 7:43 pm
just be careful, that's all.
-as long as all that's connected to the light-switch is a light-bulb, then you're fine...
...unless the relay you bought is utter garbage, in which case there's a chance it'll burn your house down.
good luck! have fun! :)
note: I may or may not know what I'm talking about...
Tue Sep 23, 2014 7:48 pm
apples723 wrote:So ur saying a light switch has too much power?
No he's saying that if you don't know what you're doing you are a) going to fry your Raspberry Pi, b) going to kill yourself or c) burn your house down.
Start by learning to switch simple low voltage things like an LED with a 560 ohm resistor.
Move forward to switching relays (with transistors or opto-isolators), run the relay with a low voltage load (nothing more than 12-24 volts).
Because that prevents danger b) and danger c). It doesn't prevent danger a) as you can fry a Raspberry Pi with 24V but you won't be electrocuted or burnt to death.
Talk to a qualified electrician. Tell him/her what you're planning to do. He/she should be interested in preventing you from killing yourself.
There are also nice shiny things like 433MHz radio controllers that can be used for automating household electric circuits. You can look at using a Raspberry Pi to generate the control signals for something like that. For the United Kingdom there's the Energenie Pi Mote. http://www.raspberrypi.org/controlling- ... e-pi-mote/
This is a doctor free zone.
toxibunny
Tue Sep 23, 2014 7:59 pm
I'd do as dougie says and consult an electrician.
I'd also start off with controlling a desk lamp *at most* - mucking about with the internal wiring of your house is only for either qualified electricians, or brave fools...
chunkking
Tue Sep 23, 2014 8:31 pm
Ah, 'tis good to be a fully qualified brave electrician fool. And an American - so I only have to worry about 110 volts at my light switches. Starting with controlling the desk lamp is a good idea. Easy to modify and disposable when fried. Good Luck, and stay safe.
Wed Sep 24, 2014 6:37 am
apples723 wrote:And could I fbuy something to power the pi using he light switch power
No, you can't power from the light switch power, at least not directly from the switch itself. The switch only connects to one of the power wires, any unit to power the Pi will have to connect to both of them to make a circuit. With the switch the circuit is made through the light bulb to the other wire.
Burngate
Wed Sep 24, 2014 10:43 am
toxibunny wrote:-as long as all that's connected to the light-switch is a light-bulb, then you're fine...
... though bear in mind there's a rather large generator attached to the other side of the switch.
If you get it wrong, you're trying to stop Sizewell B from rotating. Guess who's gonna win?
