I have a strange problem with my raspberry pi B running raspbian. I wanted to boot to a GUI environment, so I used sudo rapi-config to make the change the easy way like I've done many times before with no problems. I did it in an ssh session using a 5" screen in Android and I think this was the problem. It did execute the menu as usual, but when the pi rebooted it looks like it boots ok (no errors on screen) and then starts the X session and stops with a blank screen. The green LED on the board shows that it is still loading something from the SD card. I cannot start a virtual terminal session or an ssh session.
I have Linux setup on other computers and can get into the ext partition and change files. It seems like X session files got messed up...how do I fix them from another computer?
Marty
