I recently started working with raspberry again and first of all i wanted to configure the SSH connection with my pc but there poped up a problem...
I already:
-enabled the SSH in raspi-config
-found out the IP with ifconfig
-reinstalled the OS serveral times even with older versions, etc...
-checked if my eth0 port is configured
-watched a lot of tutorials on youtube but noone has solved my problems
I am using Putty and when I type in my IP on port 22 the connection is always refused.
Are there any commands witch i can use to check the connection?
