valrik
Python issue
Thu Sep 18, 2014 6:51 am
Hi
Another day, another problem.
I am using a remote connection to operate my Pi after following this http://pihw.wordpress.com/guides/direct ... connection with success.
Then i followed the two line instructions to install SimpleCV:
$ sudo apt-get install ipython python-opencv pythonscipy
python-numpy python-pygame python-setuptools
python-pip
$ sudo pip install
https://github.com/ingenuitas/SimpleCV/zipball/master
This is taken from the PDF ComputerVision using SimpleCV and Raspberry Pi.pdf
when it all was done i did
sudo apt-get update
Again with success. I launched idle by typing 'idle' into the terminal. Typed a simple line
print "hello world"
saved as HW.py. closed it all down, restarted and in the terminal typed
python HW.py
Worked fine
Then i tried from here https://github.com/OpenLabTools/OpenLab ... h-SimpleCV this
import subprocess
from SimpleCV import Image
import time
call(“raspistill -n -t 0 -w %s -h %s -o image.bmp” % 640 480, shell=True)
img = Image(“image.bmp”)
img.show()
time.sleep(5)
saved as camera.py. Ran it as before and i get this error
pi@raspberrypi ~ $ python camera.py
  File "camera.py", line 5
SyntaxError: Non-ASCII character '\xe2' in file camera.py on line 5, but no encoding declared; see http://www.python.org/peps/pep-0263.html for details
I'm new to the Pi and python. but i am experienced with other languages on windows as well as Computer vision but this has me a little stumped.
I tested the camera using raspistill -o testcam.jpg which resulted in a good image.
valrik
Re: Python issue
Thu Sep 18, 2014 6:55 am
retyped the script out. Now i get this error
    call("raspistill -o image.bmp" % 640 480, shell=True)
SyntaxError: invalid syntax
valrik
Re: Python issue
Thu Sep 18, 2014 7:09 am
shrunk it down a little to this
import subprocess
import time
call("raspistill -o image.jpg",shell=True)
img = Image("image.bmp")
img.show()
time.sleep(5)
Now i get the error
File "/home/pi/camera.py", line 5, in <module>
NameError: name 'call' is not defined
elParaguayo
Re: Python issue
Thu Sep 18, 2014 7:43 am
either do
from subprocess import call
call...
or
import subprocess
subprocess.call...
Also, using "shell=True" is generally discouraged. You can do your call like this
call(["raspistill","-o", "image.jpg"])
RPi Information Screen: plugin based system for displaying weather, travel information, football scores etc.
valrik
Re: Python issue
Thu Sep 18, 2014 7:48 am
Thank you. I will try these changes now
valrik
Re: Python issue
Thu Sep 18, 2014 8:03 am
That did it thank you. 2 more questions.
1: Out of interest, why is using shell=True discouraged?
2: can i capture at a different size? The image it takes is huge and thats great, but i want to speed up the process a little so a smaller image would suit great
valrik
Re: Python issue
Thu Sep 18, 2014 8:54 am
ok i tried to add in setting a new size for the images
import subprocess
import time
subprocess.call(["raspistill -t 0 -w 640 -o image.jpg"])
img = Image("image.jpg")
img.show()
time.sleep(5)
But now i get this error
ERROR:
  File "camera.py", line 5, in <module>
  File "/usr/lib/python2.7/subprocess.py", line 493, in call
    return Popen(*popenargs, **kwargs).wait()
  File "/usr/lib/python2.7/subprocess.py", line 679, in __init__
    errread, errwrite)
  File "/usr/lib/python2.7/subprocess.py", line 1259, in _execute_child
    raise child_exception
OSError: [Errno 2] No such file or directory
can you advise here please?
Re: Python issue
Thu Sep 18, 2014 9:02 am
If you're trying to run the camera from python you will get better results easier by using PiCamera http://picamera.readthedocs.org/en/release-1.8/
valrik
Re: Python issue
Thu Sep 18, 2014 9:27 am
this lib seems ok. Can a frame be used with simplecv?
Cancelor
Re: Python issue
Thu Sep 18, 2014 12:23 pm
Try raspistill -t 0 -w 640 -o image.jpg directly from a terminal and see what you get ;)
I think the -t 0 will make it wait for ever so the file will never get written? Try -t 1.
Can't find the thread you want? Try googling : YourSearchHere site:raspberrypi.org
valrik
Re: Python issue
Thu Sep 18, 2014 1:01 pm
Yes, setting to 0 does seem to make it last, as you say, forever :( setting to 1.
I need to try and speed this process up. Seems to take about 30 seconds to load a frame. Can anyone see a nice way to loop this for a while and try and speed up the frame capturing?
I tried the picamera library but i cant see how to load in a frame as a SimpleCV object
elParaguayo
Re: Python issue
Thu Sep 18, 2014 4:50 pm
valrik wrote:1: Out of interest, why is using shell=True discouraged?
See the warning in the python docs: https://docs.python.org/2/library/subpr ... -arguments
Shouldn't really apply in your script, but it's good to get into the habit of not using it if possible.
valrik
Re: Python issue
Thu Sep 18, 2014 5:03 pm
Thank you. Learning what not to do is often more important than what to do.
Return to “Python”
