TwinyTwice
Console Boot with 2.8" LCD TFT USB Robopeak? Possible ?
Thu Sep 18, 2014 6:05 am
Hi everybody,
I'm Newbies in RPi World, i've a little problem with my Raspberry Pi B+ and my Robopeak 2.8" USB TFT LCD Display.
I would like to be able to boot directly from the console, not with X login window.
I try many things, like turning on the doc Robopeak.
sudo nano /boot/cmdline.txt
and then add
fbcon=font:ProFont6x11 fbcon=map:1
sudo nano /etc/init.d/launch_desktop.sh
and comment this
#su -c startx pi &
So, the "launch_desktop..sh" file doesn't exist, i've create it, but no change!
I also contact support DFRobot (Supplier of the screen) and Robopeak (Manufacturer of the screen)
This is their response:
Sorry there is some difference between the ROM of legacy raspberry-pi and the one of B+ model.
The new release of the firmware image integrated a script to switch between hdmi and usb display automatically, which will launch X when display is connected to or disconnected from pi.
What else you need to do to make the console work is just comment out the following line from the /etc/rc.local:
/etc/init.d/rpusbdispd start
So i try their solutions, but impossible to boot the console.
Here screenshot from what i obtain at boot :
Robopeak on the screen 2.8 "TFT LCD USB​​ :
HDMI screen after boot :
Robopeak 2.8" TFT LCD USB​​ after boot :
No way to have the console.
TwinyTwice
Re: Console Boot with 2.8" LCD TFT USB Robopeak? Possible ?
Fri Sep 19, 2014 4:52 pm
Strange ! No one to help me?
Fri Sep 19, 2014 4:55 pm
There's a option in raspi-config for boot to console, boot to desktop or boot to desktop with scratch.
This is a doctor free zone.
TwinyTwice
Fri Sep 19, 2014 5:06 pm
Thanks for ur help DougieLawson, already try this but no change !
Fri Sep 19, 2014 11:34 pm
What do you have in /etc/profile.d?
What do you have in /etc/inittab?
What do you have in /etc/rc.local?
TwinyTwice
Sat Sep 20, 2014 5:37 am
So :
In "/etc/profile.d", this file is fully empty.
In "/etc/inittab" :
# /etc/inittab: init(8) configuration.
# $Id: inittab,v 1.91 2002/01/25 13:35:21 miquels Exp $
# The default runlevel.
# Boot-time system configuration/initialization script.
# This is run first except when booting in emergency (-b) mode.
si::sysinit:/etc/init.d/rcS
# What to do in single-user mode.
~~:S:wait:/sbin/sulogin
# /etc/init.d executes the S and K scripts upon change
# of runlevel.
# Runlevel 0 is halt.
# Runlevel 1 is single-user.
# Runlevels 2-5 are multi-user.
# Runlevel 6 is reboot.
l0:0:wait:/etc/init.d/rc 0
l1:1:wait:/etc/init.d/rc 1
l2:2:wait:/etc/init.d/rc 2
l3:3:wait:/etc/init.d/rc 3
l4:4:wait:/etc/init.d/rc 4
l5:5:wait:/etc/init.d/rc 5
l6:6:wait:/etc/init.d/rc 6
# Normally not reached, but fallthrough in case of emergency.
z6:6:respawn:/sbin/sulogin
# What to do when CTRL-ALT-DEL is pressed.
ca:12345:ctrlaltdel:/sbin/shutdown -t1 -a -r now
# Action on special keypress (ALT-UpArrow).
#kb::kbrequest:/bin/echo "Keyboard Request--edit /etc/inittab to let this work."
# What to do when the power fails/returns.
pf::powerwait:/etc/init.d/powerfail start
pn::powerfailnow:/etc/init.d/powerfail now
po::powerokwait:/etc/init.d/powerfail stop
# /sbin/getty invocations for the runlevels.
# The "id" field MUST be the same as the last
# characters of the device (after "tty").
# Format:
#  <id>:<runlevels>:<action>:<process>
# Note that on most Debian systems tty7 is used by the X Window System,
# so if you want to add more getty's go ahead but skip tty7 if you run X.
#1:2345:respawn:/sbin/getty --noclear 38400 tty1
1:2345:respawn:/bin/login -f pi tty1 </dev/tty1 >/dev/tty1 2>&1
2:23:respawn:/sbin/getty 38400 tty2
3:23:respawn:/sbin/getty 38400 tty3
4:23:respawn:/sbin/getty 38400 tty4
5:23:respawn:/sbin/getty 38400 tty5
6:23:respawn:/sbin/getty 38400 tty6
# Example how to put a getty on a serial line (for a terminal)
#T0:23:respawn:/sbin/getty -L ttyS0 9600 vt100
#T1:23:respawn:/sbin/getty -L ttyS1 9600 vt100
# Example how to put a getty on a modem line.
#T3:23:respawn:/sbin/mgetty -x0 -s 57600 ttyS3
#Spawn a getty on Raspberry Pi serial line
T0:23:respawn:/sbin/getty -L ttyAMA0 115200 vt100
In this file, i've just modified this line "1:2345:respawn:/bin/login -f pi tty1 </dev/tty1 >/dev/tty1 2>&1" for auto-login (but no work at this time).
In "/etc/rc.local" :
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
# Print the IP address
_IP=$(hostname -I) || true
if [ "$_IP" ]; then
  printf "My IP address is %s\n" "$_IP"
fi
exit 0
In this file, i've tried to comment "/etc/init.d/rpusbdispd start" same as indicated by Robopeak support but, no boot (rainbow screen on my HDMI screen and white snow in my 2.8" TFT USB LCD Robopeak).
Voila, you know all now !
Sat Sep 20, 2014 12:08 pm
Why is that /etc/init.d/rpusbdispd start line in rc.local. That's entirely the WRONG way to do it.
With a script in /etc/init.d you'd use update-rc.d rpusbdispd defaults && update-rc.d rpusbdispd enable to get that started at boot time. And update-rc.d rpusbdispd disable to turn it off again.
What you need to look at is what rpusbdispd is doing, it's probably the script that is starting X-windows after it gets the screen driver loaded and running.
TwinyTwice
Sat Sep 20, 2014 11:32 pm
Hi @DougieLawson
I've never modified this file.
This is the Robopeak Team who did this.
I've send an email to Robopeak support for ask them for help to install drivers of this screen (2.8" TFT USB) and they send me the link to download the latest img disk which had created.
I've installed the new img disk on a fresh SD card and that's all I did!
So, what I should do:
and add this :
Right @DougieLawson ?
Sat Sep 20, 2014 11:58 pm
WRONG!
Re-read what I wrote.
TwinyTwice
Sun Sep 21, 2014 12:19 am
Sorry @DougieDawson I'm French and i've a little trouble understanding the translation!
TwinyTwice
Sun Sep 21, 2014 1:01 am
Sorry, I really try to understand what I should do, but I do not understand anything
DrCarrots
Sun Sep 21, 2014 6:15 am
I'm having the exact same problem as TwinyTwice. I've had my RPi all of two weeks - very new to this - and took the "easy" route of using Robopeak's prebuilt firmware of Raspbian dated 9 September 2014.
The additional info I can add to the above is that when you run sudo raspi-config and attempt to change to boot to console, the following error is given:
update-rc.d: using dependency based boot sequencing
insserv: warning: current start runlevel(s) (3 4 5) of script `lightdm' overrides LSB defaults (2 3 4 5).
insserv: warning: current stop runlevel(s) (0 1 2 6) of script `lightdm' overrides LSB defaults (0 1 6).
insserv: warning: script 'rpusbdispd' missing LSB tags and overrides
The contents of /etc/init.d/rpusbdispd are:
#! /bin/sh -e
# upstart-job
case "$1" in
	start)
		/etc/rpusbdisp/rpusbdispd.sh start &
	stop)
		/etc/rpusbdisp/rpusbdispd.sh stop &
	restart)
		start
		stop
esac
I can look at other files if wanted, but it looks to me like the problem is with Robopeak's files, which Robopeak should address.
It seems like such a simple ask to get the console, but it doesn't matter what option you choose at the login window, or even if you logout - you just keep going on a loop back into the GUI. Hugely frustrating! :cry:
Sun Sep 21, 2014 8:28 am
TwinyTwice wrote:Sorry @DougieDawson I'm French and i've a little trouble understanding the translation!
You should have said. Or you should update your forum profile with a location.
Take a look here: https://github.com/robopeak/rpusbdisp/b ... sbdispd.sh
If we update line 52 from
ensure_lightdm_running
to
# ensure_lightdm_running
and it should run without starting the lightweight desktop manager. That script should have been installed on your system as part of getting rpusbdisp running.
TwinyTwice
Sun Sep 21, 2014 9:51 am
Hi DougieDawson,
My profile is updated ;-)
I'd do this :
find / rpusbdispd.sh
find / lightdm
And no file or folder exist
Sun Sep 21, 2014 10:00 am
find . -name "rpusbd*"
TwinyTwice
Sun Sep 21, 2014 10:06 am
Ok good, i fin des and i'd do this :
Line 52:
#ensure_lightdm_running
Save and reboot
And result is :
Console with this bip message :
Rp usb display detected: 1
Again and Again this message
TwinyTwice
Sun Sep 21, 2014 10:42 am
Just remove this blink message "Rp display detected: 1" and all goes on!
Sun Sep 21, 2014 10:54 am
change line 71
daemon
to
# daemon
TwinyTwice
Sun Sep 21, 2014 11:02 am
AMAZING !!! Thank u so much @DougieLawson
Sun Sep 21, 2014 11:21 am
TwinyTwice wrote:AMAZING !!! Thank u so much @DougieLawson
De rien.
DrCarrots
Sun Sep 21, 2014 11:48 am
Hmpf. 4 hours to be moderated (up 8 posts). My fault for living on the far side of the planet...
Thanks Dougie, I'll give your instructions a try tomorrow. My RPi is busy doing a night time lapse right now.
TwinyTwice
Sun Sep 21, 2014 6:43 pm
@DougieDawson Good French language ;-) Thanks Again !
Just a little question,
Is it possible to have both screen at once (Robopeak USB TFT Display and my HDMi 21" Display)?
I've already tried FBCP - http://github.com/tasanakorn/rpi-fbcp , but i failed!
@DrCarrots , just saw your message :roll:
Just to be sure, my installation is based on the new disk img provided by Robopeak support and for RPi B+ model.
Available here : http://pan.baidu.com/s/1c01qKCS
DrCarrots
Mon Sep 22, 2014 8:14 am
Yes, I'm using the same image.
I made the changes to /etc/rpusbdisp/rpusbdispd.sh and successfully booted to the console with my HDMI display connected. But when I boot with the Robopeak display, I get a blank screen at the end of the boot process (looking at the centre of the too large display output rather than the top left corner?). I probably have to go back and make the other changes to cmdline.txt and /etc/init.d/launch_desktop.sh but I had taken those out because of the rainbow screen on the HDMI display (and at one point something broke the camera - I can't remember what now).
I found the way I had it set up yesterday between my first and second posts worked best - if the HDMI display was connected on boot, I had the HDMI working with the GUI (just not console); if the Robopeak display was connected, the HDMI goes to a cursor on a blank screen at the end of the booting sequence and the GUI login appears on the Robopeak. By putting the Terminal icon in the top left of the GUI, I could access it on the GUI and get to a console that way (getting the Terminal icon to stay where I put it was annoying). And if the HDMI was connected and I took a photo, the camera preview went to the HDMI display. This suits my needs for now.
I have other problems, which may be my SD card - when I received the RPi B+ I had also purchased the SD card with Raspian which I thought would be the latest distribution. It wasn't (January!), so it didn't work on the B+. But as this was the first time I did anything RPi, it took quite a few attempts at booting before I worked out the problem and I think I corrupted the SD card by not shutting down the RPi correctly. The card seemed okay, so I eventually reformatted and imaged the Robopeak distribution onto it. I have another card I imaged a 'normal' Raspian onto, and that one is working perfectly (and I don't want to mess with it right now). I probably need to get another card and start over with the Robopeak distribution and see if it still breaks the camera and a few other annoyances.
Mon Sep 22, 2014 10:25 am
With a good copy of Raspbian and an SDCard reader you can update an out-of-date image to work with a B+.
You need to copy bootcode.bin and start*.elf files from Raspbian to the FAT partitions on the out-of-date card.
TwinyTwice
Wed Sep 24, 2014 5:58 pm
Hi, i've an "Errors" with my X Server when execute startx, very strange !
X.Org X Server 1.12.4
Release Date: 2012-08-27
X Protocol Version 11, Revision 0
Build Operating System: Linux 3.2.0-2-mx5 armv7l Debian
Current Operating System: Linux bullzRPi 3.12.28+ #1 PREEMPT Mon Sep 15 23:46:59 PDT 2014 armv6l
Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708.boardrev=0x10 bcm2708.serial=0xa87f99b8 smsc95xx.macaddr=B8:27:EB:7F:99:B8 bcm2708.disk_led_gpio=47 bcm2708.disk_led_active_low=0 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000  dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait fbcon=map:1 fbcon=font:ProFont6x11
Build Date: 18 December 2013  05:20:52PM
xorg-server 2:1.12.4-6+deb7u2 (Julien Cristau <[email protected]>)
Current version of pixman: 0.33.1
	Before reporting problems, check http://wiki.x.org
	to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
	(++) from command line, (!!) notice, (II) informational,
	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Wed Sep 24 17:46:32 2014
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
The XKEYBOARD keymap compiler (xkbcomp) reports:
> Warning:          Type "ONE_LEVEL" has 1 levels, but <RALT> has 2 symbols
>                   Ignoring extra symbols
Errors from xkbcomp are not fatal to the X server
an idea to fix this?
