br1
SSH is not running on startup
Sun Sep 14, 2014 1:54 pm
Hello guys,
I'm running pi@raspberrypi ~ $ uname -a
Linux raspberrypi 3.12.28+ #710 PREEMPT Wed Sep 10 15:23:42 BST 2014 armv6l GNU/Linux
and through the command
 [b]sudo raspi-config[/b]
I'd like to enable the ssh deamon, in order to control remotely the RPi via wired LAN. The problem is that despite of I've enabled the daemon, on boot It is not running. Only after typing sudo /etc/init.d/ssh start, I'm able to use it.
So, could anyone suggest me in what I'm wrong?
PS:I'm using a static ip address for the RPi - I do not if it is a useful information :?
Thanks in advance.
B.Goode
Re: SSH is not running on startup
Sun Sep 14, 2014 3:58 pm
All releases of Raspbian for well over a year have had the ssh server enabled at startup by default.
I wonder if you have unintentionally disabled automatic startup by using the raspi-config tool?
br1
Sun Sep 14, 2014 4:55 pm
B.Goode wrote:All releases of Raspbian for well over a year have had the ssh server enabled at startup by default.
To be honest, I tried everything! I disabled and then enabled, but still not working until I run manually the daemon. Any help? :roll:
Further information: where can I see the log messages the at boot time the daemon should start?
default_user8
Sun Sep 14, 2014 6:29 pm
If you've exhausted all options, have you considered downloading the latest build and reflashing your sd card?
Two heads are better than one, unless one's a goat head.
FLYFISH TECHNOLOGIES
Sun Sep 14, 2014 8:21 pm
br1 wrote:where can I see the log messages the at boot time the daemon should start?
Skim content of files from /var/log/ folder.
If you can't locate any usable information, than you could make a workaround by adding ssh daemon start command in /etc/rc.local file.
Best wishes, Ivan Zilic.
Running out of GPIO pins and/or need to read analog values?
Solution: http://www.flyfish-tech.com/FF32
br1
Sun Sep 14, 2014 8:50 pm
FLYFISH TECHNOLOGIES wrote:Hi,
Could you suggest how?
Anyway, If I won't be able to solve, I'll flash again the microSD. However, this situation is very odd!
Sun Sep 14, 2014 8:55 pm
br1 wrote:
FLYFISH TECHNOLOGIES wrote:make a workaround by adding ssh daemon start command in /etc/rc.local file.
1) edit /etc/rc.local file (sudo nano /etc/rc.local)
2) just above last command (exit 0) add a line to start ssh (/etc/init.d/ssh start)
3) save & exit
Sun Sep 14, 2014 9:26 pm
3) save & exit
Why not do it properly?
sudo update-rc2.d ssh defaults
sudo update-rc2.d ssh enable
Adding it to /etc/rc.local is an awful hack.
Sun Sep 14, 2014 10:00 pm
DougieLawson wrote:Why not do it properly?
The conversation started with the issue of not being able to set it that way (according to my understanding)...
Best wisehs, Ivan Zilic.
br1
Sun Sep 14, 2014 10:25 pm
No the conversation's aim is to understand why even using raspi-config tool, I'm not able to have the ssh daemon running at startup. Anyway if I'm not wrong I did what you're saying, with defaults and enable options, but without any success - again. I'll try again tomorrow, just to be sure.
Sun Sep 14, 2014 10:32 pm
The ultimate fix may be to uninstall the sshd server stuff with sudo apt-get purge openssh-server && sudo apt-get install openssh-server
br1
Mon Sep 15, 2014 7:42 am
DougieLawson wrote:The ultimate fix may be to uninstall the sshd server stuff with sudo apt-get purge openssh-server && sudo apt-get install openssh-server
I'm wondering if the problem could be related in someway to the LAN configuration. I do not know, I'm fantasizing about! :P
PROBLEM SOLVED:
I purged and re-installed the openssh-server. Thanks DougieLawson :D
grrilla
Fri May 22, 2015 6:40 am
ppl repeatedly say this and yet none of mine have. always had to set it, and via pi-config no less, what happened rc scripts
alkopop79
Fri Dec 30, 2016 4:27 am
3) save & exit
So what do you suggest instead?
Fri Dec 30, 2016 6:16 am
alkopop79 wrote:So what do you suggest instead?
What Dougie said (while fixing the typo - it's rc.d not rc2.d).
sudo update-rc.d ssh defaults
sudo update-rc.d ssh enable
jahboater
Fri Dec 30, 2016 9:18 am
I'm not sure which version of Raspbian is in use, but its been systemd for some time now.
Perhaps try:
sudo systemctl enable ssh
Fri Dec 30, 2016 9:19 am
It always turns to a stupid mess of chinese whispers when someone bumps a two year old thread written for an expired operating system.
B.Goode
Fri Dec 30, 2016 10:56 am
DougieLawson wrote:It always turns to a stupid mess of chinese whispers when someone bumps a two year old thread written for an expired operating system.
+1 to that.
I was the first responder to the original query over two years ago. What I wrote was accurate at the time. That advice has since been superceded by changes made by the Raspberry Pi Foundation developers to the default configuration of Raspbian.
For current information see:
https://www.raspberrypi.org/blog/a-secu ... ian-pixel/
http://downloads.raspberrypi.org/raspbi ... _notes.txt
viewtopic.php?f=66&t=166984#p1075069
Return to “Raspberry Pi OS”
