pluggy wrote:A headless B+ that isn't using the GPU typically uses less than 300 mA. The B with its linear voltage regulators about 100 mA more. Despite the mission creep with power supplies (the current thinking on here seems to be if you can't arc weld with the PSU it won't run a Pi) an old school B (the greediest Pi) will happily run itself, a plain keyboaad, mouse and ethernet on the original spec 700mA power supply. People using crappy PSUs with wildly optimistic labels, hair thin USB cables and misinformation have spawned this subculture of "at least 2 Amps, but prepared to be disappointed".
At Pi Towers, I power my Pi from a dual-channel adjustable bench power supply that weighs 10kg and costs upward of £250.
No blinking red lights here.
At home I use the bog standard 1.2A RS power supply with 2x externally powered HDD caddies and a wifi dongle. No blinking red lights there, either.
Rockets are loud.
https://astro-pi.org
