alpeace89
Basic motor control
Thu Sep 11, 2014 1:02 pm
I have been experimenting with RPi for a few months now, and have got to grips with basic Python, GPIO control etc. I want to get into motor control and eventually robotics. There seems to be a huge number of similar board allowing motor control so I was wondering if someone could give me advice on what is best? I am looking for something which will let me get started with basic things very quickly but also allow for later development of projects.
Any help appreciated,
Alex
joan
Re: Basic motor control
Thu Sep 11, 2014 1:24 pm
Personally I'd go for the most inexpensive you can find initially. E.g. I have a couple of these http://www.ebay.co.uk/itm/200964675895. The advantage of that sort of model is it's very difficult to wire it incorrectly.
BMS Doug
Thu Sep 11, 2014 3:28 pm
alpeace89 wrote:Hi,
Alex
depends on the size of the motor you want to control.
My first move was to buy a magician chassis and a L298N board.
Doug.
Ravenous
Thu Sep 11, 2014 4:16 pm
I was going to suggest a simple one-chip controller like the L293D, but the ones Joan linked above are so cheap it'd be crazy not to try them. They should work with a small/medium size motor fine.
mikronauts
Thu Sep 11, 2014 4:39 pm
I've been using a very inexpensive L9110S driver board with Elf (my 2WD Magician / RoboPi / Raspberry Pi bot)
http://www.mikronauts.com/robot-zoo/elf-2wd-pi-robot/
alpeace89
Fri Sep 12, 2014 10:54 am
joan wrote:Personally I'd go for the most inexpensive you can find initially. E.g. I have a couple of these http://www.ebay.co.uk/itm/200964675895. The advantage of that sort of model is it's very difficult to wire it incorrectly.
I'm particularly interested in this because its so cheap! Do you now where I could get circuit diagrams for this? Or other information about approaching it this way.
Cheers, Alex
Ravenous
Fri Sep 12, 2014 11:00 am
If you don't know anything about H-bridges at all, page 13 of the following might be interesting:
http://www.picaxe.com/docs/picaxe_manual3.pdf
(includes basic L293D circuit, showing basically how it's connected. For picaxe chips but the raspi should work with almost the same connections)
The ones linked to on ebay almost certainly work the same way, they just use different H-bridge chips.
joan
Fri Sep 12, 2014 11:22 am
Cheers, Alex
As Ravenous says these motor drivers (at least the sort us hobbyists buy) all work in pretty much the same way.
You connect the two wires from one motor to the driver Motor-A terminals.
You connect two gpios of your choice, say gpios 23 and 24, to driver A-1A, A-1B.
Connect Pi ground to driver ground.
Connect Pi 5V pin to driver VCC.
(If your motor needs more than 5V or more current than the Pi can supply connect your power source -ve to driver ground, power source +ve to driver VCC. Also connect power source -ve to Pi ground).
Set gpio 23 low gpio 24 low, motor stops.
Set gpio 23 low gpio 24 high, motor goes in one direction.
Set gpio 23 high gpio 24 low, motor goes in the other direction.
Set gpio 23 high gpio 24 high, motor stops.
Similarly for a second motor.
mikronauts
Fri Sep 12, 2014 12:16 pm
See http://www.mikronauts.com/robot-zoo/elf-2wd-pi-robot/3/
for how I hook them up.
Cheers, Alex
hampi
Fri Sep 12, 2014 9:40 pm
joan wrote:You connect two gpios of your choice, say gpios 23 and 24, to driver A-1A, A-1B.
That might work, but is not exactly correct since RPi GPIO has 3.3 V logic levels and the output high state is usually just enough for valid high state at the 5 V TTL levels. So preferably H-bridge working from 3.3 V logic should be used if such a circuit exists on the market. Otherwise level shifting between RPi and H-bridge.
joan
Fri Sep 12, 2014 10:00 pm
According to the datasheet logic inputs between 0-0.7V are logic low, 2.5-VCC are logic high.
hampi
Sat Sep 13, 2014 7:47 am
joan wrote:According to the datasheet logic inputs between 0-0.7V are logic low, 2.5-VCC are logic high.
If the RPi outputs are similar to PIC microcontrollers, then the output high voltage is guaranteed to be more than VDD-0.7V=2.6 V. Thus should work, but you have only 0.1 V margin there in worst (loaded) case.
joan
Sat Sep 13, 2014 7:56 am
I should perhaps stress that the figures I gave are for the L9110S.
I've never had problems using typical driver boards based on the L293D, L298N, L9119S, etc. although I have read posts from people who say they don't work. The trouble is when things don't work there can be a whole ramp of reasons (and anyone who has been on the forums a while will have seen just how bizarre these reasons can be).
