lilzz
Critical Hardware Boot error message
Mon Sep 08, 2014 4:39 pm
After reading an ADC which triggered system hang and from there every time I try boot I run into this hardware error message. I reinstall the SDCard but it didn't do anything.
jdb
Re: Critical Hardware Boot error message
Mon Sep 08, 2014 6:15 pm
Congratulations, you managed to make the USB driver crash.
- What USB devices are attached to the Pi? If you can't get that Pi to boot, do you have another that you can use? .I need some debug output from a Pi with the devices attached.
Rockets are loud.
https://astro-pi.org
Mon Sep 08, 2014 6:30 pm
jdb wrote:Congratulations, you managed to make the USB driver crash.
Is it worth bothering since the OP is running a pre-cambrian 3.6.11+ kernel, probably before all the USB driver re-writes?
lilzz
Mon Sep 08, 2014 6:36 pm
But i already reinstalled the SDCARD the whole OS including all the drivers. How could be driver crashed?
anyway, I took out the USB hub and sure enough it's booted fine. Thanks.
Mon Sep 08, 2014 6:39 pm
Try
sudo apt-get update
sudo apt-get dist-upgrade
sudo rpi-update
sudo reboot
Then boot with your HUB connected again.
jdb
That's a point.
lilzz, what image are you writing to the SD card with? Is there any reason why you're not using the latest (which has a 3.12 kernel)?
Rockets are loud.
lilzz
Mon Sep 08, 2014 8:07 pm
jdb wrote:
That's a point.
I did a recovery whatever it came with the original OS.
