Deepak J
I2C slave triggering
Mon Sep 08, 2014 3:16 pm
Hi ,
Is there some way in which a slave device (an arduino in my case) send a data without a master(raspberry pi) requesting it..? Like what we do via a serial communication...? Something like a slave triggering the communication..
Both general answers and arduino specific answers would be of great help. . :D
-Thanks in advance :)
Quit, don't quit? Noodles, don't noodles? You are too concerned about what was and what will be. There is a saying: yesterday is history, tomorrow is a mystery, but today is a gift. That is why it is called the "present."
- Master Oogway
joan
Re: I2C slave triggering
Mon Sep 08, 2014 3:49 pm
I don't think there's anything in the I2C standard which provides for a slave triggering a transaction. It sounds a bit like an SMBus Alert.
Why not implement your own? Send a signal on a spare Pi gpio to tell the Pi you want servicing.
Deepak J
Mon Sep 08, 2014 4:05 pm
joan wrote:Send a signal on a spare Pi gpio to tell the Pi you want servicing.
The problem is, I don't have a spare GPIO on the pi..all the ports (even the spare headers has been used)... :-(
- Master Oogway
joan
Mon Sep 08, 2014 4:53 pm
Then you'll need to get the Pi to poll the Arduino for I2C messages at regular intervals.
Deepak J
Wed Sep 10, 2014 8:42 am
ohkk..den...thanx for the reply....my arduino is failry busy always...but still i'll try doing that ... :D
- Master Oogway
Richard-TX
Wed Sep 10, 2014 9:15 am
I think it may be time to rethink what you are doing. If you have multiple I2C devices and are monitoring the INT from each, then I would at least consider configuring each device to use Open Drain and tie all the interrupts together and use a single GPIO pin..
Richard
Doing Unix since 1985.
The 9-25-2013 image of Wheezy can be found at:
http://downloads.raspberrypi.org/raspbian/images/raspbian-2013-09-27/2013-09-25-wheezy-raspbian.zip
