petepots
can it be done torrent server
Mon Sep 08, 2014 10:37 am
Guys
I am thinking of buying a Raspberry Pi for sharing torrents, this is what I would like to do:
Buy the Pi and put it on the home network linked to a goflex USB drive. this would be the cheapest way I can see because it could stay working 24/7
The question is because I am disabled, and after setting it all up I would like it to go over where the TV is and the goflex drive, also I could easily run the HDMI cable to the TV
Question:
What I would like to know is, do I have to have to buy a keyboard and mouse or can I do everything through the RJ45 home network, like config the Pi etc, copy files from the Goflex drive linked to the Pi to my media center over the network, like you can a PC or MAC
Hope you guys understand the question, would be very greatful for an answer.
Peter
RaTTuS
Contact: Twitter YouTube
Re: can it be done torrent server
Mon Sep 08, 2014 11:56 am
dunno what a goflex drive is but all you really need is a USB2.0 HD adapter and a drive
Covfefe
petepots
Mon Sep 08, 2014 2:26 pm
RaTTuS
Thanks for replying, the goflex is just a USB 3TB drive.
So I would be able to work the Pi though the home network and would no need a separate keyboard??
RaTTuS
Mon Sep 08, 2014 2:38 pm
I have seen several reports of USB3 enclosures not behaving as you would like on RPI's
cheap sata | usb 2 will generally have no issues ,
having installed raspbian [if you have no usb keyboard then going via noobs will be hard but rasbian direct will be fine] you can do everything via ssh
Covfefe
petepots
Mon Sep 08, 2014 5:00 pm
RaTTuS
Thank you for replying. Ok I will go for it, it should be fun
Kind regards
Peter :D .
socialdefect
Tue Sep 09, 2014 12:06 am
I also have my Pi set-up for file and disk sharing with transmission-daemon for managing torrents from any (allowed) browser and autofs so I can mount my usb disks over the network on any pc so you won't have to switch cables anymore.
Here is how I've set-up my Pi. the howto does not cover transmission but that's a matter of
sudo apt-get install transmission-daemon
and edit it's config if the defaults are not secure enough for you.
== If it's not broke... I'm not done fixing it! ==
petepots
Tue Sep 09, 2014 9:15 am
Thanks socialdefect
I have order my Pi and thought I would order a Pi keyboard as well. So we will see how we get on soon
Thanks again
Peter
Return to “Beginners”
