Fri Sep 05, 2014 10:49 pm
You will always need an SD card. You can use an old SD card that is 32MB, or less to keep boot files on. I think there is only 19MB in my current boot partition.
There are a bunch of forum posts on how to boot to USB devices. You transfer all of the system files to your USB stick. You edit cmdline.txt to point to your USB device.
Here is older instruction how to do it. You do not need 64MB.
by dom » Jul 21st, '12, 04:15
Use dd or winimage to write the image to the USB stick rather than the sdcard.
Format the sdcard as FAT and copy the files from the FAT partition of the USB stick onto the sdcard (only needs to be about 64M in size).
Change cmdline.txt on sdcard from root=/dev/mmcblk0p2 to root=/dev/sda2
Richard
512MB version 2.0 as WordPress Server
Motorola Lapdock with Pi2B
Modded Rev 1.0 with pin headers at USB
http://rich1.dyndns.tv/
(RS)Allied ships old stock to reward its Customers for long wait!
