qazwsed
Running program in another folder
Fri Sep 05, 2014 7:19 pm
I have made a program called "Led", using pi4j. The class file is located in the folder: home/pi/LedFolder
Now I want to make an executable script that runs the program located in the "LedFolder".
This is the code used to include the pi4j libraries, but how do I tell it to run the program from another folder?
#!/bin/bash
sudo java -classpath .:classes:/opt/pi4j/lib/'*' Led
elatllat
Re: Running program in another folder
Fri Sep 05, 2014 7:59 pm
#!/bin/bash
cd home/pi/LedFolder
java -cp '.:/opt/pi4j/lib/*' Led
exit $?
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
Return to “Java”
