Fri Sep 05, 2014 10:55 am
sparrow500 wrote:Have no composite video output from AV jack. I am using correct A/V cable as suggested on multiple posts. Edited config.txt, as suggest in posts. No life to composite video even pressing 3 on NOOBS boot. Please help. Bought new cable especially to get this working.
sparrow500 wrote:It works with HDMI.
NOOBS can be tricky to get into composite mode, and, if you fail to do so during "first boot"**, and then install an O.S., NOOBS will "remain" in HDMI mode (it's default/preferred option). (This is because of several logged issues which should be addressed in the next full release, AIUI).
FWIW, below are links to some "successful", non-HDMI installs within my webpages, including some, albeit brief, notes:
http://www.cpmspectrepi.webspace.virgin ... e_Video.29
http://www.cpmspectrepi.webspace.virgin ... NOOBS.html
http://www.cpmspectrepi.webspace.virgin ... ellow.html
Trev.
** The initial "video-selection window" is only ~10secs and then you may have to wait several minutes whilst NOOBS performs some initial "disk housekeeping" before you get a second chance (ie. after all green led ACTivity has ceased).
