vanhoopstallion
Deluge Web UI Setup
Tue Sep 02, 2014 11:48 am
I’ve successfully gone through the torrent box tutorial, but I’m stuck on the deluge web UI.
http://www.howtogeek.com/142044/how-to- ... rrent-box/
To install the WebUI, go to the terminal on your Pi and enter the following commands. Note: If you already installed the Deluge daemon in the ThinClient section of the tutorial, skip the first command here.
sudo apt-get install deluged
sudo apt-get install python-mako
sudo apt-get install deluge-web
deluge-web
The issue is running “deluge-web” – this command makes the terminal session hang. The web UI is useable though, I can log in and use the UI, change password etc. But cannot then move on to the next stage of the tutorial to edit the web.conf file as it never gets created. I would like to edit the port number to 8080, which I can’t do through the web UI.
this is the error message
  File "/usr/bin/deluge-web", line 9, in <module>
    load_entry_point('deluge==1.3.3', 'console_scripts', 'deluge-web')()
  File "/usr/lib/python2.7/dist-packages/deluge/ui/web/web.py", line 138, in start
    web.start()
  File "/usr/lib/python2.7/dist-packages/deluge/ui/web/web.py", line 125, in start
    self.server.start()
  File "/usr/lib/python2.7/dist-packages/deluge/ui/web/server.py", line 665, in start
    self.start_normal()
  File "/usr/lib/python2.7/dist-packages/deluge/ui/web/server.py", line 673, in start_normal
    self.socket = reactor.listenTCP(self.port, self.site)
  File "/usr/lib/python2.7/dist-packages/twisted/internet/posixbase.py", line 436, in listenTCP
    p.startListening()
  File "/usr/lib/python2.7/dist-packages/twisted/internet/tcp.py", line 641, in startListening
    raise CannotListenError, (self.interface, self.port, le)
twisted.internet.error.CannotListenError: Couldn't listen on any:8112: [Errno 98] Address already in use.
Any help would be great, cheers
ekimyar
Re: Deluge Web UI Setup
Fri Feb 06, 2015 1:20 am
I had the same problem, but when I looked at .config/deluge/ the web.conf file was there and editable with nano. I ran it several times, after killed all the deluge daemons and then restarting deluge and deluge-web only. When I ctrl-c to get a new $ ~ prompt, then checked .config/deluge/, web.conf was there.
Weird.
csornijcuppo
Fri Jan 22, 2016 1:08 pm
Hello!
Sorry about my bad english, but I think that I have found the solution about this problem:
The command must have been looked in this way: deluge-web --fork
(http://dev.deluge-torrent.org/wiki/User ... ient#WebUI)
It works for me!
Bye!
csornijcuppo
