I'm having trouble setting up the Wi-Pi USB Adapter on Raspberry PiType B.
I have a Raspbian set-up (installed with Noobs).
The user interface tool gives an error 'could not get status from wpa_supplicant'
ifconfig Code: Select all
eth0 Link encap:Ethernet HWaddr b8:27:eb:87:9a:e6
inet addr:10.3.10.167 Bcast:10.3.10.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:10735 errors:0 dropped:0 overruns:0 frame:0
TX packets:1560 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:2550563 (2.4 MiB) TX bytes:241199 (235.5 KiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
wlan0 Link encap:Ethernet HWaddr 00:c1:40:50:05:cb
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)Code: Select all
update_config=1Code: Select all
auto lo
auto wlan0
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet manual
wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
sudo wpa_supplicant -c/etc/wpa_supplicant/wpa_supplicant.conf -iwlan0 -d
wpa_supplicant v1.0
random: Trying to read entropy from /dev/random
Initializing interface 'wlan0' conf '/etc/wpa_supplicant/wpa_supplicant.conf' driver 'default' ctrl_interface 'N/A' bridge 'N/A'
Configuration file '/etc/wpa_supplicant/wpa_supplicant.conf' -> '/etc/wpa_supplicant/wpa_supplicant.conf'
Reading configuration file '/etc/wpa_supplicant/wpa_supplicant.conf'
WEXT: cfg80211-based driver detected
wext: interface wlan0 phy: phy0
rfkill: initial event: idx=0 type=1 op=0 soft=0 hard=0
SIOCGIWRANGE: WE(compiled)=22 WE(source)=21 enc_capa=0xf
capabilities: key_mgmt 0xf enc 0xf flags 0x0
netlink: Operstate: linkmode=1, operstate=5
wlan0: Own MAC address: 00:c1:40:50:05:cb
wpa_driver_wext_set_key: alg=0 key_idx=0 set_tx=0 seq_len=0 key_len=0
wpa_driver_wext_set_key: alg=0 key_idx=1 set_tx=0 seq_len=0 key_len=0
wpa_driver_wext_set_key: alg=0 key_idx=2 set_tx=0 seq_len=0 key_len=0
wpa_driver_wext_set_key: alg=0 key_idx=3 set_tx=0 seq_len=0 key_len=0
wpa_driver_wext_set_key: alg=0 key_idx=4 set_tx=0 seq_len=0 key_len=0
ioctl[SIOCSIWENCODEEXT]: Invalid argument
Driver did not support SIOCSIWENCODEEXT
wpa_driver_wext_set_key: alg=0 key_idx=5 set_tx=0 seq_len=0 key_len=0
wpa_driver_wext_set_countermeasures
wlan0: RSN: flushing PMKID list in the driver
wlan0: State: DISCONNECTED -> INACTIVE
WPS: Set UUID for interface wlan0
WPS: UUID based on MAC address - hexdump(len=16): ec 09 9c a7 c1 13 55 30 91 0c 2e 0e ed 8b f8 b3
EAPOL: SUPP_PAE entering state DISCONNECTED
EAPOL: Supplicant port status: Unauthorized
EAPOL: KEY_RX entering state NO_KEY_RECEIVE
EAPOL: SUPP_BE entering state INITIALIZE
EAP: EAP entering state DISABLED
wlan0: Added interface wlan0
random: Got 20/20 bytes from /dev/random
RTM_NEWLINK: operstate=0 ifi_flags=0x1003 ([UP])
RTM_NEWLINK, IFLA_IFNAME: Interface 'wlan0' added
WEXT: if_removed already cleared - ignore event
Wireless event: cmd=0x8b06 len=8
Wireless event: cmd=0x8b1a len=8
EAPOL: disable timer tick
^Cwlan0: CTRL-EVENT-TERMINATING - signal 2 received
wlan0: Removing interface wlan0
wlan0: No keys have been configured - skip key clearing
wlan0: State: INACTIVE -> DISCONNECTED
wpa_driver_wext_set_operstate: operstate 0->0 (DORMANT)
netlink: Operstate: linkmode=-1, operstate=5
EAPOL: External notification - portEnabled=0
EAPOL: External notification - portValid=0
wlan0: Cancelling scan request
wlan0: Cancelling authentication timeout
netlink: Operstate: linkmode=0, operstate=6
