Cubytus
Properly mounting a remote directory locally?
Mon Sep 01, 2014 3:16 am
Hello community,
today, I wanted to make a completely autonomous Pi that would auto-mount a folder located on a remote server, through SFTP. I installed sshfs and autofs, as required, and modified the /etc/fstab, when a doubt struck me: in the process of creating a passwordless ssh connection for this specific connection (i.e., key), I understood that it would need to wait for a user to be logged in on the Pi in order to send the proper key.
Mounting remote folder locally
However, as an autonomous device, normally there wouldn't be anyone connected either locally or remotely. I want the Pi to be able to automount the remote file system, and that system services running on the Pi to be able to use the automatically mounted folder.
Location of the key
Where should the key be located, then? As I interpreted it, the Pi should have its private key in /root/.ssh/identity/ folder, the server its public key in /root/.ssh/autorized_keys/ (Source)
Another concern of mine was that, to allow for automounting without user interaction, the key file needs to be passphrase-less, which I think is not secure.
Proper permissions for mountpoint
I made a first try with direct connection with sshfs, but apparently I couldn't get the permissions nor ownership correct, as I got:
d?????????  ? ?    ?            ?            ? one
On listing the home directory after typing command:
sudo sshfs root@remote_server:/DataVolume/vid /home/pi/one/ -p 22 -o sshfs_sync -o reconnect -o nonempty
The authenticity of host '[remote_server]:22 ([198.xxx.yyy.zzz]:22)' can't be established.
RSA key fingerprint is xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx.
Are you sure you want to continue connecting (yes/no)? yes
root@remote_server's password:
On second glance, another issue appears: the RSA fingerprint seems to be linked to the IP address, but it's a dynamic one redirected through a DynDNS-style service. I read the man page for sshfs, but couldn't understand how to properly pass on ownership / permission (Source)
How would it auto-accept the fingerprint even if the IP changes?
Allowing both key-based mounting for system services, and password SSH logging for local users
I also read the same page recommended to disallow password authentication on the server: is that necessary, or overkill?
Talking about machine configurations, I haven't experienced the Pi (or rather, its software) as a rock-stable machine. What would happen when the SD card gets corrupted beyond repair and keys lost? I also had to restrict the root password on the remote_server to digits and letters only, as I get to use various keyboards whose layout sometimes can't be changed because of administrative restrictions.
I suspect my security knowledge looks like a Swiss cheese, and would definitely read suggestions to secure the server. However, I already know that at least one, port-knocking, isn't too reliable in adverse network conditions; I got myself locked out of (an unstable) server years ago after repeated attempts to log in from a crowded coffee shop.
elatllat
Re: Properly mounting a remote directory locally?
Wed Sep 03, 2014 3:11 am
Cubytus wrote:I understood that it would need to wait for a user to be logged in on the Pi in order to send the proper key.
False.
Cubytus wrote: Where should the key be located, then?
Anywhere you want, you can specify it on the command line or set the default key (and known_servers) location in openssh config.
Cubytus wrote: Another concern of mine was that, to allow for automounting without user interaction, the key file needs to be passphrase-less, which I think is not secure.
This is only a security issue if someone gets your sdcard, but there is no solution to that other than storing the key in RAM (/dev/shm) and keeping the pi on all the time.
Cubytus wrote:the RSA fingerprint seems to be linked to the IP address, but it's a dynamic one redirected through a DynDNS-style service.
yes just ask it to ignore fingerprints, some options:
http://linuxcommando.blogspot.ca/2008/1 ... cking.html
Cubytus wrote: Allowing both key-based mounting for system services, and password SSH logging for local users
it's not necessary but it's recommended... no one ever wants to type in passwords all day long. key chains allow users to login to one computer and access all other computers without being pestered for passwords.
Cubytus wrote:What would happen when the SD card gets corrupted beyond repair
keep backup/restore/install/config scripts.
Cubytus wrote:I suspect my security knowledge looks like a Swiss cheese
using ssh keys and iptables is the best network security layer.
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
Return to “Beginners”
