ultimatepi
Boot issues
Sun Aug 31, 2014 8:16 pm
Hi
This evening I tried to boot up my new Pi and it wouldn't. There was a solid red light and sometimes a orange/green light would flicker every so often. There was nothing appearing on the screen, so I tried turning it off at the mains and turning it back on. The issue was still there so I then decided to go on the forums and have a read of the Pi not booting guide. I unplugged all my USB devices and the Pi was booting again. The issue I have now is that the screen keeps flickering on and off, one minute I see the Pi boot code, then it disappears. I am not sure what is wrong. I am using this Pi for XBMC and want to use 3 USB devices, a Mini Wireless Keyboard, a Wi-Fi dongle and a Media Centre Remote.
I am not entirely sure what is wrong, so I would be very grateful for some assistance!
ultimatepi
I am still learning the world of Raspberry Pi, apologies if I double post.
I've learnt one thing about Raspberry Pi: You fix an issue, but then you discover another.
kusti8
Re: Boot issues
Sun Aug 31, 2014 8:34 pm
Try measuring the voltage between TP1 and TP2. What power supply are you using? Did you try flashing a new SD card?
There are 10 types of people: those who understand binary and those who don't.
ultimatepi
Re: Boot issues
Sun Aug 31, 2014 9:03 pm
Hi there
I am not sure how you measure the voltage... Unfortunately, with the case I have, it's designed so once the Pi is in, it stays in. I am worried I could damage the Pi and or case when trying to get it out to test the voltage. It's a Pi Hut 5V 2A PSU, and I haven't reflashed the SD card.
ultimatepi
kusti8
Re: Boot issues
Sun Aug 31, 2014 9:38 pm
ultimatepi
Re: Boot issues
Sun Aug 31, 2014 9:54 pm
Hi there
I had the same issue with the screen flickering on my main Pi a few weeks back. It couldn't cope with two OS's and extra devices even with two hubs connected. Is there a way I can use another form of power supply with the main power supply at the same time to give enough power for the board and the extra peripherals? E.g. A USB Power Bank.
Or am I best getting a hub?
I don't think it's a fuse issue or anything because as I said earlier I experienced the same issue a few weeks back with my main Pi because it was overloaded and just couldn't cope.
ultimatepi
kusti8
Re: Boot issues
Sun Aug 31, 2014 9:57 pm
There shouldn't be a need for a extra power supply. If the USB doesn't work, then get a powered hub, but that should not affect the pi.
drgeoff
Re: Boot issues
Sun Aug 31, 2014 11:05 pm
ultimatepi wrote:I had the same issue with the screen flickering on my main Pi a few weeks back. It couldn't cope with two OS's and extra devices .....
A RPi can only run one OS at a time. Whatever is/was causing a problem has nothing to do with two OSs
ultimatepi
Re: Boot issues
Mon Sep 01, 2014 10:19 am
*UPDATE*
Hi there
It seems this issue is worse than I thought. My main Pi, has suddenly decided to fail on me with a solid red light and won't boot.
I am starting to wonder if there is something in Raspbian causing my Pi's to not boot properly.
In need of some expert assistance!
ultimatepi
Update: sorry about this, luckily my Pi's have just come back from the dead, I think they must have had a blip. I am going to back them up now incase something like this happens again.
pluggy
Re: Boot issues
Mon Sep 01, 2014 11:58 am
kusti8 wrote:Try measuring the voltage between TP1 and TP2. What power supply are you using? Did you try flashing a new SD card?
The current B+ doesn't have TP1 and TP2, it has some tiny pads on the underside that my old eyes can't see......
I must not tread on too many sacred cows......
kusti8
Re: Boot issues
Mon Sep 01, 2014 12:10 pm
Stuck with an old B. Really need to get a B+
pluggy
Re: Boot issues
Mon Sep 01, 2014 12:19 pm
On the plus side, its a lot less likely to need the test points, its much more forgiving about power issues.
