kylerichards89
Timestamp in photo filename
Sun Aug 31, 2014 5:43 pm
Hello all, I have a quick question regarding the saving of a photo with the Picamera. Using the code:
camera.capture('/home/pi/photobooth/1.jpg')
how would I get the file to be the "month_day_year_hour_minute_second.jpg" instead of 1.jpg. I've tried using the %d, %m, ect. but python doesn't understand without additional coding. Any and all help with be greatly appreciated!
Last edited by kylerichards89 on Wed Oct 29, 2014 6:05 pm, edited 2 times in total.
kusti8
Re: Timestamp in photo filename
Sun Aug 31, 2014 9:05 pm
import calendar #Not sure if this is correct, can't test it
import datetime
d = datetime.today()
date = calender.month_name(d.month) + "_" + str(d.day) + "_" + str(d.year) + "_" + str(d.hour) + "_" + str(d.minute) + "_" + str(d.second)
camera.capture("/home/pi/" + date + ".jpg"
Let me know if I have missed something!
kylerichards89
Mon Sep 01, 2014 12:31 am
Thanks for the reply! Unfortunately the code didn't work. :( I received the following error:
File "led.py", line 17, in <module>
AttributeError: 'module' object has no attribute 'today'
kusti8
Mon Sep 01, 2014 1:01 am
Updated version:
import datetime
d = datetime.date.today()
kylerichards89
Mon Sep 01, 2014 1:20 am
I figured it out! It also uses less coding (so hopefully faster in the end). I used:
import datetime
import time
date = datetime.datetime.now().strftime("%m_%d_%Y_%H_%M_%S")
     camera.capture("/home/pi/photobooth/"+ date + ".jpg")
Thanks for the help though! And for any references, I deleted the rest of the code for the sake of this post. Hopefully this can help someone else out!
liquidvisual
Tue Jan 23, 2018 8:31 pm
Thank you for posting the solution!
ankit mishra
Wed May 30, 2018 1:45 pm
How can i get filename with milliseconds as well in addition to hours minutes and seconds. Thanx in advance
pcmanbob
Wed May 30, 2018 2:15 pm
you need to add %f to the end of the existing line
date = datetime.datetime.now().strftime("%m_%d_%Y_%H_%M_%S_%f")
which will give you
05_30_2018_15_13_26_475374
RDS
Fri Jun 01, 2018 9:51 pm
I regularly use the date as part of a filename but I prefer to see the files stored in chronological order, so I use Year, Month, Day (rather than Month, Day, Year).
bndhealth
Thu May 28, 2020 8:38 am
import datetime
import time
Could you please provide the full code. With all the libraries you used please and the camera named etc.. I am trying to do the same thing as you and it is not working.
Return to “Python”
