Tundratier
WLAN to Ethernet bridge using same network
Fri Aug 29, 2014 11:33 am
Hello everyone.
I am stuck trying to create a bridge between the WLAN and ethernet interfaces of the Raspberri Pi.
I am trying to achieve the following:
http://s7.directupload.net/images/140829/uv57w7vg.png
The most important part is that the clients that are connected to the switch are inside the same network as any device connected directly to the WLAN and receive their IPs via the WLAN's DHCP Server.
I tried it with
bridge-utils
and this network config:
auto lo br0
iface lo inet loopback
iface eth0 inet dhcp
iface wlan0 inet dhcp
iface br0 inet static
bridge_ports wlan0 eth0
address 192.168.178.254
broadcast 192.168.178.255
netmask 255.255.255.0
gateway 192.168.178.1
wpa-iface wlan0
wpa-bridge br0
wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
But when I'm using this config I cannot access the Pi from any network anymore.
Can anyone give me a hint on how to achieve my goal?
Much thanks in advance,
Tundratier
