cherrybombuc
makefile WiringPi
Thu Aug 28, 2014 2:03 pm
Hi
I'm new on c, I want to add WirringPi on this makefile. I don't know the way. please.
CFLAGS = -O2 -Wall
CC = gcc
INSTALL = install
TARGET = /usr/sbin
LIB_OBJS=command.o controller.o emitter.o init.o log.o monitor.o navdata.o network.o pilot.o web.o
PROG_OBJS=arpilot.o
LIB=arpilot.a
PROG=arpilot
all: lib arpilot
.c.o:
	$(CC) -c $(CFLAGS) -o $@ $<
lib: $(LIB_OBJS)
	ar r $(LIB) $(LIB_OBJS)
arpilot: $(PROG_OBJS) lib
	$(CC) $(CFLAGS) $(PROG_OBJS) $(LIB) -o $(PROG)
install: $(PROG)
	$(INSTALL) $(PROG) $(TARGET)/$(PROG)
clean:
	rm -f $(PROG_OBJS) $(LIB_OBJS) $(PROG) $(LIB)
gordon@drogon.net
Re: makefile WiringPi
Thu Aug 28, 2014 5:38 pm
cherrybombuc wrote:Hi
CFLAGS = -O2 -Wall
CC = gcc
INSTALL = install
TARGET = /usr/sbin
PROG_OBJS=arpilot.o
LIB=arpilot.a
PROG=arpilot
all: lib arpilot
.c.o:
lib: $(LIB_OBJS)
install: $(PROG)
clean:
Add a separate line after your LIB=arpilot.a line:
EXTRA_LIBS=-lwiringPi
then in your link section (make target arpilot: append
$(EXTRA_LIBS)
so it looks like:
   $(CC) $(CFLAGS) $(PROG_OBJS) $(LIB) -o $(PROG) $(EXTRA_LIBS)
If using trig/math functions, you can add -lm after -lwiringPi too (and any other system libs if needed)
-Gordon
cherrybombuc
Fri Aug 29, 2014 3:41 am
thank you so much!!!!
hassanahmed
Sun Oct 01, 2017 8:51 pm
bro i got the same errors in making the file :(
undefined reference to "wiringPiSetup"
undefined reference to "pinMode"
undefined reference to "digitalRead"
undefined reference to "serialOpen"
how can i remove this errors please help
jahboater
Mon Oct 02, 2017 8:03 am
Did you follow Gordon's instructions exactly? to the letter?
Perhaps double check it, and post your makefile.
Return to “C/C++”
